Oil Pressure in 85 Chevy K10 350
Topic: Oil Pressure in 85 Chevy K10 350 (Read 8207 times)
rounds07
December 07, 2013, 11:45:04 am »
Just changed the oil in my truck now the oil pressure gauge reads 0 while at idle and to the max while accelerating. Also the truck randomly shut off on me twice while driving. Any solutions?
rich weyand
Re: Oil Pressure in 85 Chevy K10 350
December 07, 2013, 11:49:32 am »
Did you check the oil level again once the truck was run for a bit and the oil filter had a chance to fill up?
rounds07
December 07, 2013, 12:03:11 pm »
Yea checked it still reading full
bd
December 07, 2013, 12:08:52 pm »
Make sure the oil pressure sender is still plugged in and the sender wire isn't dangling against the exhaust.
rounds07
December 07, 2013, 06:09:20 pm »
Its idling hard and wants to shut off too.
454Man
Why Race?
December 07, 2013, 06:18:27 pm »
Did you change the filter? If so did you fill the filter with oil b4 putting it back on?
What's under the hood??? If you have to ask maybe we shouldn't race...
rounds07
December 07, 2013, 07:58:56 pm »
No I just put oil on the gasket
454Man
Why Race?
December 07, 2013, 08:02:37 pm »
Please take off the filter and see if there is oil inside
rounds07
December 07, 2013, 08:20:08 pm »
Yep their is oil in the filter
454Man
Why Race?
December 07, 2013, 08:39:32 pm »
Id get An oil pressure gauge hooked up to the side of the oil filter housing. Are you sure you don't have any wires touching like BD suggested?
rounds07
December 07, 2013, 08:41:02 pm »
Where is the oil pressure sender located
454Man
Why Race?
December 07, 2013, 09:40:31 pm »
Behind the distributor to the right
rounds07
December 07, 2013, 10:16:05 pm »
Thanks for the help. I will check it out in the morning. Let you know what I find.
bd
December 08, 2013, 01:15:07 pm »
Quote from: rounds07 on December 07, 2013, 08:41:02 pm
Look right next to and above the oil filter, otherwise look where
454Man
noted.
