Author Topic: Vacume  (Read 6759 times)
Offline DCustom
Vacume
« on: December 08, 2013, 12:06:22 am »
OK, I have a 84 with a/c. There is a vacume hose (black with white stripe) coming from the control panel that is not hooked up to anything nor is it plugged off. Can someone help me with this
Re: Vacume
« Reply #1 on: December 08, 2013, 12:12:32 am »
There should be a black round vacuum canister that it should be hooked up to.  I can take a picture of it tomorrow and post it if someone hasn't already done it.
Offline DCustom
Re: Vacume
« Reply #2 on: December 08, 2013, 12:21:53 am »
Thanks zieg. Are you talking about the canister on the right kick panel?
Re: Vacume
« Reply #3 on: December 08, 2013, 03:27:18 am »
No, it is under the hood
Re: Vacume
« Reply #4 on: December 08, 2013, 11:43:10 am »
It may also be on the drivers side but that black looking ball is what that hose needs to be connected to and the ball needs manifold vacuum
Offline DCustom
Re: Vacume
« Reply #5 on: December 08, 2013, 12:47:11 pm »
this one was under the dash...after giving up last night I went back out there fresh this morning and there is a canister behind the heater box that you cant see that had a available place so I put it there....I wish I had played with the a/c heater controls a little before I tore everything down to see what was and was not working....but I do thank you for the info....Im starting under the hood next week
