Author Topic: 85 C10 Accessory Brackets  (Read 3198 times)
Offline jbreeves85C10
« on: December 08, 2013, 01:26:53 am »
So I pulled the engine and tore it down to the block. Rebuilt with everything new except pistons and rods and crank. Did the valve job and got ready to get 'er ready to drop back in the truck. I cannot for the life of me remember how the accessory brackets were mounted and the shop manual is not much help. Does anyone by chance have a pic or diagram of the A/C, alternator, steering brackets mounted? Attached is what I have so far but I'm out of brackets and still have holes on the passenger side head :-) Mine was a little different than the manual.
Offline Engineer
Re: 85 C10 Accessory Brackets
« Reply #1 on: December 08, 2013, 08:44:12 am »
Your upper alternator bracket needs to be bolted to the front most intake manifold bolt on the passenger side.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
« Reply #2 on: December 08, 2013, 11:37:42 am »
Ditto, everything else appears to be ok.  You won't use every hole up on the passenger head.
