Author Topic: Throttle help  (Read 4291 times)
Offline tjwelch2012
Throttle help
« on: December 10, 2013, 07:58:07 am »
I have a '76 C20 454 big block.  I'm having trouble with it idling too high.  So high that I can go about 30mph without pushing the gas pedal.  I have to give it a quick goose on the gas pedal before it idles down to normal.  Any suggestions??
Offline darmentle
Re: Throttle help
« Reply #1 on: December 10, 2013, 08:14:38 am »
What type of carb are you running?
Offline 81_Chevy
Re: Throttle help
« Reply #2 on: December 10, 2013, 09:10:36 am »
x2
and is this while its cold or hot?
Offline 454Man
  • Why Race?
Re: Throttle help
« Reply #3 on: December 10, 2013, 09:47:25 am »
Seems like the Fast idle screw needs adjustment. If the carb has one its easy to do
What's under the hood??? If you have to ask maybe we shouldn't race!
Offline blazing816
Re: Throttle help
« Reply #4 on: December 10, 2013, 10:46:44 am »
X2
My truck had same symptoms as yours, and I did what '454Man' said. Found the fast idle screw and turned it down (and I mean mine was jacked, I had to adjust pretty far). What I did until I figured out it was fast idle from these forums, is just un-hooked the choke. It was harder to start cold, but mine was jack up so high I thought it would blow my engine, it was at like 3500-4000 rpms
Re: Throttle help
« Reply #5 on: December 10, 2013, 12:06:54 pm »
OE Specs:
Fast idle should be adjusted between 1,600 - 1,700 RPM in neutral with engine at operating temperature and fast idle screw on highest step of the fast idle cam.
