Author Topic: CS series alternator upgrade?  (Read 16965 times)
Offline 454Man
  • Why Race?
« on: December 14, 2013, 11:20:48 am »
For anyone who has done this. what adaptor part number did you use. Do I need one with a resistance wire? Now that I have my high powered stereo system installed I'm in need of a better charging system. I'm also going to have fog lights running as well anyone?
What's under the hood??? If you have to ask maybe we shouldn't race!
Offline nlauffer
Re: CS series alternator upgrade?
« Reply #1 on: December 14, 2013, 09:03:52 pm »
I am curious to find out your answers. I think the resistance wire is needed if you have a gauge instead of light.  And I have a 4.3 V6 in my driver but I built a 350 for my square.
Offline 454Man
  • Why Race?
« Reply #2 on: December 14, 2013, 09:10:59 pm »
Thanks for the support :-)
Offline 454Man
  • Why Race?
« Reply #4 on: December 15, 2013, 10:13:17 am »
Yea I saw that cap, but I'm just trying to see what the end results from people with our trucks have had. I also found this site that was a little more helpful
http://temp.corvetteforum.net/c3/zman//Electronics/Alternator01.htm
Offline jason d o
« Reply #5 on: December 15, 2013, 01:05:43 pm »
I used the connector ec-82 bought from napa for less than 20 bucks, and it works perfect. I have a 86 chevy pu with a 350 with a factory volt gauge. I didnt have to use any special brackets either, a direct bolt in.
Offline 454Man
  • Why Race?
« Reply #6 on: December 15, 2013, 01:13:52 pm »
Hey thanks! Nice ride btw
Offline 454Man
  • Why Race?
« Reply #7 on: December 15, 2013, 01:21:23 pm »
Did you get the cs130 or the cs144?
Offline jason d o
« Reply #8 on: December 16, 2013, 01:57:03 am »
thank you.   the cs 144
Offline 454Man
  • Why Race?
« Reply #9 on: December 16, 2013, 06:07:12 am »
Wow now that's really what I wanted to hear is the bigger alternator fit with out any mods out diff bracket. Hope I have the same luck. How's the charging at idle?
Offline ehjorten
« Reply #10 on: December 16, 2013, 10:17:50 am »
I put a CS130 105 A in my '69 Chevelle.  I didn't use any adapters though...I rewired so it looks factory.  It's been in there for about 5 years with no problems.
-Erik-
Offline 454Man
  • Why Race?
« Reply #11 on: December 16, 2013, 02:32:05 pm »
That is what I'm after... A factory look. Well almost :-)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #12 on: December 17, 2013, 10:14:19 pm »
Here's a link to my CS130D Upgrade on my 78 C20.
I've had 5 or 6 of the old style alts and none lasted bearings problems n such mostly.
This alt has been in the truck for over 2 years and not one single problem yet.  I love it and would buy another one and from the same people no question
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9090.285
FYI.  You can fot almost whatever belt pulley you need to it.  I got a serp pulley cuz that was the setup i went to, as the V-belts weren't lasting the strain the higher amp alts put on them.
Offline 454Man
  • Why Race?
« Reply #13 on: December 17, 2013, 10:19:13 pm »
Thanks this is all good info! Note to self v belts don't last long after they've been run with the higher amp alternator... I think I see a gator back in my future :-) or two
Offline 454Man
  • Why Race?
« Reply #14 on: December 18, 2013, 11:52:02 am »
I noticed two things after reading your thread. The One you have the cs130 alternator body style, which is the reason for no installation issues. I'm wanting to get the cs144 and that has a bigger case. I may just end up with what the junk yard has also the need for a smaller pulley... Did that solve your lower than 14v charging issue at idle?
