Author Topic: electronic lockers?  (Read 9018 times)
Offline jarhead76
  • 76 Silverado K20 camper special
electronic lockers?
« on: December 15, 2013, 06:27:05 pm »
have a 76 K20 with 14 bolt rear end and a Dana 44 front. its my daily driver and i take it hunter camping in the mountains all year round. i was thinking of getting set of electronic lockers for it. if i do whats a good brand to go with or is there a better option out there?
90 suburban V1500
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: electronic lockers?
« Reply #1 on: December 15, 2013, 07:16:42 pm »
Do you have a full floater 14 bolt
Offline STxMunky
« Reply #2 on: December 16, 2013, 09:57:45 am »
I thought all 14 bolt rears were fully floating? I could be wrong. :)
'77 LWB, 350, sm465, np205, 14ff & D60 kingpin
Offline ehjorten
« Reply #3 on: December 16, 2013, 10:20:15 am »
There aren't any e-Lockers for a 14-bolt unfortunately.  There is not enough room in the differential for the electro-magnet.  If you want a selectable locker for the 14-bolt you are going to have to go ARB.
-Erik-
Offline pholliday1
« Reply #4 on: December 16, 2013, 11:17:33 am »
Not all 14 bolts are FF some are semi floaters. If your 14 is a FF and open differentials then your next choice is a Detroit locker.
Offline jarhead76
« Reply #5 on: December 16, 2013, 07:05:20 pm »
i believe that are full floaters. i have to remove the axle shaft to get the drums open. so i think that's what they are if not how would i tell.
90 suburban V1500
Offline dvdswan
« Reply #6 on: December 17, 2013, 12:22:11 pm »
that is the easiest way to tell.  semi-floating the drums pull off the with out removing the axle shafts.
FF axle drum... http://www.askjeffwilliams.com/auto-mechanic-tips-training/how-to-change-truck-drum-brakes/
SF axle drum... http://we-crash.proboards.com/thread/26962/8-lug-3-ton-rearends?page=2
« Last Edit: December 17, 2013, 01:02:27 pm by dvdswan »
Offline pholliday1
« Reply #7 on: December 17, 2013, 12:53:31 pm »
buy a Detroit and put it in, you'll be very happy............
Offline jarhead76
« Reply #8 on: December 17, 2013, 08:13:55 pm »
thank you vary much.  what a bout the front. i don't have locking hubs (that will soon change) i have know idea how to tell what it is ether than its a Dana 44
90 suburban V1500
Offline pholliday1
« Reply #9 on: December 18, 2013, 09:56:28 am »
Post a pick of the diff.... as far as lock out hubs go, maybe not so fast....... depending on what transfer case you have things might be a little more complicated. what does the top of your 4wd knob say? you may have a np203 transfer case, which is a full time transfer case. Search part time conversion for np203 case .
Offline ehjorten
« Reply #10 on: December 18, 2013, 12:18:06 pm »
e-Lockers are available for the D44 front-end, but they cost nearly as much as an ARB.  You are looking at around $800 retail for just the locker!  A Detroit will cost you about $600, so it is only a couple hundred more for a selectable locker if you are going for it.
-Erik-
Offline dvdswan
« Reply #11 on: December 18, 2013, 12:44:31 pm »
its a daily driver, I would go with a LSD in the front.  having a locker in the rear would be plenty.
Offline jarhead76
« Reply #12 on: December 18, 2013, 06:59:51 pm »
ya its a np203.  after reading the thread about converting the 203 i don't really see a point. with a air locker in the rear i should be good. unless I'm missing something.
« Last Edit: December 18, 2013, 07:36:08 pm by jarhead76 »
90 suburban V1500
