Author Topic: 86 k10 fuel gauge reading x2  (Read 22173 times)
Offline cmason052@gmail.com
  • newbie
Re: 86 k10 fuel gauge reading x2
« Reply #15 on: December 19, 2013, 01:11:23 pm »
The gauge is my profile pic
86 chevy k10 350 6in lift
How bout that old farm truck
Offline rich weyand
« Reply #16 on: December 19, 2013, 01:16:35 pm »
I can't blow that up to see anything.  Does it have a model number on it anywhere?  They have different internals, even though the exterior is the same.
  • newbie
« Reply #17 on: December 19, 2013, 01:50:01 pm »
No I dint c any numbers just on that gold sticker
  • newbie
« Reply #18 on: December 19, 2013, 01:52:35 pm »
I dont c any numbers just on the gold sticker if your useing your phone u can touch and hold on pic then save it or make it your wall paper on phone
Offline rich weyand
« Reply #19 on: December 19, 2013, 03:46:54 pm »
OK.  Yeah, I don't see anything.  Autometer makes several of the fuel gauges, as shown here.
http://www.autometer.com/cat_gaugesearch.aspx?pg=2
I don't believe it needs an external resistor.  See instructions here.
http://www.autometer.com/productPDF/2650-1079-00rC.pdf
But note that they make a 0-90 ohm gauge (which is what our sender units need) and a 0-30 ohm gauge (which was correct for sender units on GM vehicles before 1965).  If this is a 0-30 ohm unit, it will read empty at empty, and full between a third and half a tank.  Above that it will always read full.
« Reply #20 on: December 20, 2013, 09:06:13 am »
I could send u a pic in email maybe it says the pic isis to large to post on here.I like your truck by the way is that a stock grill painted
There is a whole topic devoted to resizing pictures to upload to the forum.
Offline rich weyand
« Reply #21 on: December 20, 2013, 09:38:16 am »
It's the stock grill,  think.  All chromed, it just looks dark in that picture.
  • newbie
« Reply #22 on: December 20, 2013, 01:43:02 pm »
O it looks sweet so did u c the pic idk where to go with it ill go get a tester today maybe if u think me fixing the pic so u can c it will help ill try
Offline rich weyand
« Reply #23 on: December 20, 2013, 01:53:32 pm »
You just need a little multimeter from Radio Shack that will measure ohms.  Disconnect the green (sender) wire from the gauge, and then measure the resistance from the disconnected green wire to the black (ground) wire.  If it reads 90 ohms full, then the sender and wiring are OK and the problem is probably that you have the 0-30 ohm gauge.
  • newbie
« Reply #24 on: December 20, 2013, 02:00:17 pm »
Ok ill just rent fuel pressure testerit comes with a meter and I can return it and it will be free form parts store
