Author Topic: 86 k10 fuel gauge reading x2  (Read 22172 times)
Offline cmason052@gmail.com
  • newbie
« on: December 17, 2013, 11:39:06 pm »
Hello iam new here and would surely appreciate some help. I bought truxk with new tank, fuel ggauge its reading double I put ten gallon s in it says iam full but rely shes only half I pulled gauge it has four wires I dont want to short it out  I dont know maybe its simpel wires drive me nuts hopimg someone can tell me what wirrs should read what  or how to go about this . Thank you
I dont want my level to get stuck in tank always full bit iam gessing its the wires
86 chevy k10 350 6in lift
How bout that old farm truck
Re: 86 k10 fuel gauge reading x2
« Reply #1 on: December 18, 2013, 06:50:09 am »
      Is your truck a single or dual tank truck ?
Offline Boone83K10
« Reply #2 on: December 18, 2013, 08:49:38 am »
few questions...
1. is it dual tank like bake said? if you do, could be the selector valve... if not see below.
2. do you have a multimeter? if so, since you have gauge off...what is the reading at the pink wire behind fuel gauge. 0 is empty - around 90 is FULL.
3. check the sending unit wire on top of the tank. you can see it if you sit in front of rear wheel and look above tank. it will be either black, blue or purple and is a post press on connection.
my thinking is the actual sending unit is bent or incorrect for application.
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
  • newbie
« Reply #3 on: December 18, 2013, 12:47:29 pm »
Signal tank
  • newbie
« Reply #4 on: December 18, 2013, 12:53:35 pm »
Thanks for reply this sight is sweet but I am perty sure all wires are black on gauge ill take a pic of it maybe I vould trase them to colers idk
  • newbie
« Reply #5 on: December 18, 2013, 03:25:33 pm »
Ok so red is ignition Black is ground Green must come from tank. I was hoping I could juat flip wires bit not gona be abel to do that mustbe in tank it wont let me post pic  there are red ing black grownd and green
Offline rich weyand
« Reply #6 on: December 18, 2013, 05:36:22 pm »
Disconnect the green wire.  Measure the ohms between that wire and ground.  Whatcha got?
BTW, is there a resistor across the two outside terminals of the gauge?
  • newbie
« Reply #7 on: December 18, 2013, 06:47:49 pm »
No could I just connect a wire between where it supost to be ill have to het tester were does it belong? Thanks for your help u think the resistor is the problem I never thought about that I had a pull gauge on my Jeep before and I rember seeing that
Offline rich weyand
« Reply #8 on: December 18, 2013, 08:49:23 pm »
I have no clue what you just typed.  Disconnect the green wire from the gauge.  Measure the resistance in ohms with an ohmmeter from the green wire to the black wire.  Also, take the resistor off (I assume it's there) and measure the resistance in ohms of the resistor.
  • newbie
« Reply #9 on: December 18, 2013, 09:02:52 pm »
there is no resistor. Could I make one .the gauge is sport comp
Offline rich weyand
« Reply #10 on: December 19, 2013, 12:39:37 am »
What do you mean, "the gauge is sport comp"?
  • newbie
« Reply #11 on: December 19, 2013, 11:23:10 am »
Its an after market gauge sport comp is the brand
Offline rich weyand
« Reply #12 on: December 19, 2013, 12:24:18 pm »
What is the part number on the back?  Should be a number like 3314 or 3317.
  • newbie
« Reply #13 on: December 19, 2013, 01:01:10 pm »
2511 76 I dont c one this number is on a sticker that says tested thank u for your help by the way
  • newbie
« Reply #14 on: December 19, 2013, 01:07:18 pm »
I could send u a pic in email maybe it says the pic isis to large to post on here.I like your truck by the way is that a stock grill painted
