Author Topic: Edelbrock Carb adapter?  (Read 17465 times)
Offline rich weyand
Re: Edelbrock Carb adapter?
« Reply #15 on: January 01, 2014, 11:43:28 pm »
You'll get better mileage with a Qjet than either a Holley or Edelbrock, and I think in the adjacent thread he says mileage is one goal.
But you get better mileage and performance from any of these carbs properly tuned than you will from any of them poorly tuned.
I would spend that money instead on the NGK A/F ratio meter ($250 from amazon) and use it to properly tune the carb he's got.
« Reply #16 on: January 02, 2014, 04:07:41 am »
rich would that be the only type of meter you would recommend?
Offline rich weyand
« Reply #17 on: January 02, 2014, 07:37:44 am »
The NGK is the only one I've used.  It's relatively cheap, and it has the really nice NGK five-lead, wide-range O2 detector.
Five leads plus chassis ground is three circuits: heater circuit, temp sensor circuit, and O2 detector circuit.
Offline jpatters13
    • 74' Chevy Truck Project
« Reply #18 on: January 02, 2014, 09:58:38 am »
I called Edelbrock and they confirmed that with the 305 and a stock setup, the engine calls for a 500 cfm carb.  I chose to order a rebuild kit and take a shot at going through the Quadrajet first.  If that works it will produce the most gas mileage.
84 Silverado K10
74 Custom Deluxe C10
Offline rich weyand
« Reply #19 on: January 02, 2014, 10:06:39 am »
I think that's your best choice.  Lots of people on here with knowledge of the Qjet internals, too, so shout if you got questions once you get into it.
« Reply #20 on: January 02, 2014, 08:35:00 pm »
If Mileage is you goal Quadrajet is your best bet.  They will preform just as well as the others if properly setup also.
« Reply #21 on: January 02, 2014, 11:01:24 pm »
now we're thinking and its cheaper to rebuild a qjet then buy a new holley
Offline rich weyand
« Reply #22 on: January 03, 2014, 12:06:46 am »
And with the money you save you can buy the A/FR meter, and get it dialed in!  I'm a big fan of A/FR meters.  :-)
Offline jpatters13
« Reply #23 on: January 18, 2014, 06:52:11 pm »
Okay, I really need some advice. I ordered the Rochester book by Doug Roe and it doesn't have step by step instructions on rebuilding the carb. I bought the recommended rebuild kit and a new float. The truck finally quit running today and isn't getting any fuel now.  To be honest, I am scared to deat to try to rebuild the thing myself because I am clueless about the inner workings and all the thousands of adjustments.  I am stuck and need some good advice on next steps.  Should I just try to find a carb mechanic here in Tuscaloosa?  Should I attempt the rebuild myself having never done it before?  Should I just pony up the cash for a rebuilt carb? HELP PLEASE!!!
84 Silverado K10
« Reply #24 on: January 18, 2014, 08:00:37 pm »
They are pretty easy to rebuild.  here is  pretty good video.
http://www.powerblocktv.com/episodes/MC2009-18/quadrajet-rebuild
If your intimidated I have a buddy that may have time to rebuild it for a fee.  he is in Rock Creek.  How long can you have it down?
Offline jpatters13
« Reply #25 on: January 18, 2014, 08:03:35 pm »
Thanks. I need to have it back on the road ASAP. It is a daily driver for my daughter. Any idea what the fee would be? I have the rebuild kit and float already.
84 Silverado K10
« Reply #26 on: January 18, 2014, 08:07:09 pm »
Wow cool daily driver!  Let me call him.
Offline jpatters13
« Reply #27 on: January 18, 2014, 08:14:35 pm »
Thanks. Yeah, she is a junior in HS and the truck seems to be the subject of many conversations when they see her pull up in it. She is a country girl at heart.
84 Silverado K10
« Reply #28 on: January 18, 2014, 08:35:51 pm »
That is awesome.  I called him, he said he is going to be out of town starting tomorrow for at least a week.
Offline jpatters13
« Reply #29 on: January 18, 2014, 08:55:49 pm »
Thanks for checking. I think I am about to just order an Edelbrock 500 CFM carb from Jegs and be done with it. I have to get it back on the road quickly.  Any idea what the difference is between the Performer series and the Thunder series? Both seem to have the same size bore and jets.
Performer - http://www.jegs.com/i/Edelbrock/350/9903/10002/-1
Thunder - http://www.jegs.com/i/Edelbrock/350/18019/10002/-1
84 Silverado K10
