Author Topic: column shift issues  (Read 3185 times)
Offline kyllrkoala
column shift issues
« on: December 30, 2013, 03:04:47 pm »
Hopefully you all can help me here. I'be recently started to restore a 76 c20 with 3 on the tree. I was having issues with it getting stuck in gear and was unable to shift. I could get it every once in a while by messing with the shifter but once I got home it wouldn't shift anymore. I know the tranny is good due to installing a floor shifter as a temp fix so I could drive it until I had the time to get it fixed. So is there any ideas out there that could help fix this issue.? I've heard of using a 3/16 drill bit but I have no clue what to look for. This is kinda of a new adventure for me.
76 Chevy C20 Custom Deluxe longbed
1976 Chevy C20 Custom Deluxe
355 ci
Re: column shift issues
« Reply #1 on: December 31, 2013, 11:40:53 am »
Have you inspected the linkage to see where the binding was originating from?
captkaoscustoms.com
squarebody.biz
Offline kyllrkoala
« Reply #2 on: July 07, 2014, 01:37:19 pm »
hi, sorry it took my a while to reply. ive been extremely busy with work. the binding is on the column side. i have a floor shifter in for now and its working great. i put most of it back together to try to see if anything was broken but it doesnt seem and if it is and from what i can tell and feel nothing is really lose at all. i spoke to the guy i got the truck from and he said that some of the parts were welding for a short term fix. ive been trying to find a new column to put in but its seems almost impossible unless i order a brand new one. which may be the case if i cant fix it. is there a way i can check to see if the alignment was thrown off?
355 ci
