Author Topic: TH400 Shavings and Questions  (Read 4008 times)
Offline ChevyJoe
« on: December 30, 2013, 04:52:18 pm »
After finally getting the th350 out and th400 in, I filled it up with fluid, ran it, filled it, and drove it. It was having a problem at first with going into gear, it was like neutral in all positions (with wheels off the ground). After warming up some more, I revved it up more (no tach) and it finally kicked into gear. Took it around the block, 1st was working good, nice hard shift to 2nd, but it wouldn't shift to 3rd. Had to be doing 40mph+ for it to shift. After finding out the adjustment spot in the vacuum, I ended up doing about 1 1/4 turns counter-clockwise and now it shifts better. However, it downshifts all the time, on or off the gas, when in 3rd. Why does it do this?
I drove it home and drained the fluid. Here's the results:
in the drain pan
in the trans pan.
They aren't steel but seem to be brass. Did some research, but couldn't find anything brass that would do this in a TH400?
However this piece was in between the filter and valve body:
Seems like the spacer but the ones online don't step down in size like this. Is this the wrong size?
Looking up numbers on the tranny, it appears to be from a 69 Camaro if that helps. Has sat for the past 10 years in a shed.
Any help is appreciated!
83 C10 Stepside DD- 350/350, 10 Bolt GovLock
77 K20 Flatbed Plow truck- Slow, low budget project
Offline achevy1978
Re: TH400 Shavings and Questions
« Reply #1 on: December 30, 2013, 05:57:38 pm »
if brass i would say its a bushing or thrust washer...either way there is a problem and it needs to be taken apart i think
Offline Engineer
« Reply #2 on: December 30, 2013, 08:35:07 pm »
Yup. Bushing or thrust washer. Anyway things are not good.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline ChevyJoe
« Reply #3 on: December 30, 2013, 09:04:17 pm »
Hard to replace? Never done an auto trans repair before. So it probably has nothing to do with the spacer? Because it looks chewed up on the smaller side, but the shavings don't seem to match the way it is chewed.
Offline Engineer
« Reply #4 on: December 30, 2013, 09:15:01 pm »
Total tear down.
The brass bushings are in the gear train and it is the last thing to come out.
