Transmission dont go into gear?
Topic: Transmission dont go into gear? (Read 5016 times)
ChevyRay07
December 31, 2013, 02:44:54 pm »
I had a TH350 transmission which went bad so I got a 700r4 transmission which it was "rebuilt" so I installed it put the transmission fluid in and when I put the reverse gear in, it when it fine then I tried any of the other gears it wouldn't go foward so I wanted to see If anyone would know what's wrong??
bd
Re: Transmission dont go into gear?
December 31, 2013, 03:18:39 pm »
When you initially filled the transmission, did you check the fluid level with the engine running in park? Did you then recheck the fluid level after shifting it between reverse, drive and park?
ChevyRay07
December 31, 2013, 03:41:39 pm »
I checked it on parked it showed it didn't have enough and then I put more into it it look like it had enough but it won't go into gear.
bd
December 31, 2013, 06:49:04 pm »
Did you reuse the TH350 dipstick? Did you remove the trans pan for any reason? What torque converter did you use?
ChevyRay07
December 31, 2013, 07:05:59 pm »
Yeah it's the same dipstick for the th350 and I didn't touch the pan or nothing they gave me the transmission and the TC and I place it on the tranny and put it in then turn the car on and didn't want to catch any gears just reverse. I first put 12 quarts of trans oil and then added cause I thought it needed more but didn't work either.
bd
December 31, 2013, 08:19:11 pm »
Will it shift into gear and transfer torque to the driveline if you disconnect the external linkage and shift it manually using the shift lever at the transmission (don't attempt this unless the vehicle is safely on jack stands with the tires off the ground, the park brake is firmly applied, and you're completely clear of the wheels, with an assistant nearby)? If it goes into gear using the shift lever at the trans, correct/adjust the linkage.
Otherwise, since you just purchased the 'rebuilt' trans and your confident it's full of fluid (and the fluid isn't foamy), contact the seller, so you don't forfeit any warranty.
ChevyRay07
January 01, 2014, 01:09:48 pm »
It just stays in neutral nothing happens. After I manually shift it into gears.
bd
January 01, 2014, 03:00:22 pm »
You don't have a transfer case in neutral, do you? And, the converter is bolted tight to the flexplate?
The problem could be as simple as an improperly installed filter. Or, it could be more serious. Don't void your warranty; contact the seller.
ChevyRay07
January 01, 2014, 03:12:38 pm »
Well I'm guessing I don't have it on neutral. Yes they are tight. One of my neighbors checked it out and said that the tranny isn't good and that the valve body isn't sending oil to gears for it to shift. And I contacted the seller and said he would come today and I was wondering about the pressure switch does? Because I have order a kit for the lock up but I just decided to do it externally does that maybe have something to do to it?
bd
January 01, 2014, 03:22:53 pm »
The converter lock-up circuits have no effect on the transmission going into gear. However, once you get the transmission up and shifting, you'll need the TCC functioning or the trans will overheat and die.
ChevyRay07
January 01, 2014, 03:37:19 pm »
So then it should be mechanical I'll just let the seller see it and see what his going to do
