Electrical
Some of my guages dont work
Topic: Some of my guages dont work (Read 5819 times)
ChevyRay07
January 01, 2014, 05:29:18 pm »
I was wondering what would be wrong with my gas gauge, oil gauge and motor temperature gauge? They don't show the accurate levels.
I have a 1985 Chevy Scottsdale.
Last Edit: January 01, 2014, 05:30:52 pm by ChevyRay07
bake74
Re: Some of my guages dont work
January 01, 2014, 05:59:39 pm »
Do you have any other gauges in the cluster that do work properly (besides speedometer), or are you having a issue with all your gauges in your cluster ? If that is it I would first check the connection to your cluster and make sure it is secure and clean.
It really sounds like you have a whole cluster issue than 3 different gauge issue's.
74 k10, 77k10 Tom
rich weyand
January 01, 2014, 07:06:48 pm »
Are all your ground wires in place? Gauges show voltage levels. If I send 3 volts to a gauge, but the grounds aren't connected, it could see 5 volts or 1 volt or whatever. Since these gauges all have senders with ground references other than the cab, that's a hint.
You should have the following grounds:
- ground wire from battery to alternator bracket.
- ground wire to top cross member of radiator support.
- ground strap from RHS rear engine head to firewall.
- ground strap from LHS front engine head to frame rail.
Boone83K10
January 01, 2014, 08:44:01 pm »
yeah first check the plug on the back of the cluster since it sounds like all the gauge besides the speedo aren't working. if that is good, then you need to trouble shoot each separately.
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
ChevyRay07
January 01, 2014, 08:50:36 pm »
My battery gague works right but the rest don't. So I guess something is wrong with the gauges right?
rich weyand
January 01, 2014, 10:31:02 pm »
Unlikely to have a multiple-gauge simultaneous failure. It is either a bad ground or a connector issue.
ChevyRay07
January 02, 2014, 12:28:12 am »
Well I have a group from the engine and then on the body chassis so I'm guessing I need more grounds?
rich weyand
January 02, 2014, 07:25:15 am »
You need to check that each of those grounds above are present, and that they are good connections, with clean mating surfaces, and that they're tight. The get corroded or loose, and then stuff starts acting up.
cramezl
January 02, 2014, 09:31:49 am »
Sub'd for same problem
Sent from my HTC Hero S using Tapatalk 2
Electrical
