Author Topic: Carb/Timimg Issue  (Read 2778 times)
Offline ben.pigg.5
Carb/Timimg Issue
« on: January 02, 2014, 10:55:48 am »
Hello i have a 1979k10 4x4 which i picked up for a fairly cheap price with a 454 in it. It has a Holley 750 DP on it and is very temperamental. Most days it will run amazing then all of a sudden it wont idle runs rich spits back through the carb and just wont run.So far ive rebuild the Holley done smaller jets (due to running rich) new furl pump filter and even went as far as a regulator and also done a timing check with new plugs and still nothing my next thing s the distributor. If anybody has insite it would be greatly appriciated
1984 K10 350/700r/np208
1979 K10 454/TH400/Np203w/part time kit
Offline rich weyand
Re: Carb/Timimg Issue
« Reply #1 on: January 02, 2014, 11:26:47 am »
Intermittent contact on the electric choke terminals will do that.  Make sure the contacts are clean and the choke is getting 12 volts consistently whenever the ignition is ON.
If you take the air cleaner off and turn the ignition to ON (don't start it) you should be able to watch the choke gradually open after several minutes.
When it is running crappy, take the air cleaner off and see if the choke has opened up.
« Last Edit: January 02, 2014, 11:28:48 am by rich weyand »
Offline Boone83K10
« Reply #2 on: January 02, 2014, 09:13:05 pm »
Yeah sounds like the choke staying on (closed). You should have zero volts with ignition off and twelveish when on. I bet that's your problem.
1966 Mercury Comet - Built 429 (First Car/Show Car)
1983 Chevrolet K10 - Built 350 (Winter Toy)
1992 Chevrolet Lumina Euro (Sold @ 265,000 miles)
2003 Ford Escape 4x4 - Mac Perf. Intake/Exhaust (Wifes' DD)
2007 Mercury Milan - Steeda Tuned (Summer Toy)
