Author Topic: Suggestions on removing old rubber bushings? Help!  (Read 8836 times)
Offline Welshboy
« on: October 13, 2006, 05:58:00 pm »
Hi , I've just removed my sway bar and need to replace the bushings.  Trouble is, they probably have not been removed for years and I can't push them or the metal sleeve out.
Anybody have any hints?
Thanks, Gawain
'78 Chevy K10, 6" lift
Offline lowc10
Re: Suggestions on removing old rubber bushings? Help!
« Reply #1 on: October 13, 2006, 07:46:00 pm »
an air chisel will be your best bet
Offline lotopp79
press
« Reply #2 on: October 15, 2006, 11:52:00 am »
getthem pressed out at a machince shop costs a little but is the safeest way to go
Offline Pushrod
Re: press
« Reply #3 on: October 16, 2006, 12:00:00 am »
Cut'em up, The replacements should include hardware.
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
« Reply #4 on: April 11, 2011, 07:35:21 pm »
I know this is old, but I have the same question. Does anyone have other ideas besides taking them to get pressed out? I was thinking of borrowing a vice or renting a ball joint press and trying to get that to work because both of those ideas are free. Ive been soaking them too.
« Reply #5 on: April 11, 2011, 11:50:21 pm »
burn them out with a torch
Offline Grim 82
« Reply #6 on: April 12, 2011, 08:47:10 am »
+1 for the gas wrench, even if it's just a little MAPP gas torch if you don't have access to oxy-acetylene. Second choice would be to mangle them with a sawzall and air hammer until they see things your way.
« Reply #7 on: April 12, 2011, 02:13:38 pm »
     With a big enough C clamp, you can cut one side of the rubber off, and using a round piece of pipe that is the same size of the sway bar, you can make a home made press very easy.  I did it with mine and worked very easy and did not take any time at all.
