Author Topic: This is going to sound wierd!!  (Read 5360 times)
Offline 87scottsdale
« on: January 14, 2014, 05:23:58 am »
Ok so I pick up this already machined 350 block from a friend. .030 over,lined bored etc. I am re cross hatching the cylinders since it has set for a little bit and had some small surface rust spots.
So I am thinking what else I need to get or have done before I assemble. I know I need an oil pan for it since it didn't come with one. So I start looking for dipstick location.
Guess what? There is no dipstick hole machined in the block.. I know awesome. So I have been having trouble finding and oil pan. I figure maybe some fellow chevy owners have ran into this same problem.
Numbers on the block are as follows
GM 3970010
Front tab  V0409TBX
Re: This is going to sound wierd!!
« Reply #1 on: January 14, 2014, 06:22:52 am »
Ok well I went and rechecked everything and I did happen to find the oil dipstick location. Located on the driver side,but it goes all the way through the block.
Dipstick goes down through the head mounting surface. Is this common for Driver side blocks? What oil dip stick do I use?
« Last Edit: January 14, 2014, 06:29:25 am by 87scottsdale »
« Reply #2 on: January 14, 2014, 07:34:59 am »
TBX is the engine code for either a 1970 or 1979 350, truck engine.  Any drivers side dipstick tube and dipstick matching that application should work fine
Offline LTZ C20
« Reply #3 on: January 14, 2014, 08:38:09 am »
Zieg is right on the money. I have a GM performance crate block and the dipstick hole is in exactly the same place. I got a mr gasket dress up kit couple years back. I use that provides stick and tube. Works fine, reads proper. Should be able to get one at any auto parts store or summit/jegs.
LTZ Cheyenne C20
