Author Topic: pls help big fuel leak  (Read 9248 times)
Offline jaime
« on: January 15, 2014, 02:23:52 am »
Turned truck on an  bunch of gasoline leaked underneath I think its the fuel selector from tank to tank it leaked really bad really dont know tbi fuel system were lines r pls help big puddle were headers come out underneath  pls help asap  it leaks badly pls help its scary its inside garage any help well needed drove truck 80 miles it was fine next morniing fuel was all over the place
Offline jaime
Re: pls help big fuel leak
« Reply #1 on: January 15, 2014, 03:10:37 am »
Pls help the fuel leaks underneath motor it spills on headers were they go out to exhaust pipes
« Reply #2 on: January 15, 2014, 05:42:27 am »
well you need to verify where its leaking, at one point you said its under the motor then you talk about the tank valve. a simple replacement of the fuel line shouldn't be hard you just need to figure out where and what line is leaking.
« Reply #3 on: January 15, 2014, 07:20:53 am »
     As Irish said, sounds like you have a fuel line that busted, easy to fix, you need to find the leak first and repair it.
Offline jaime
« Reply #4 on: January 17, 2014, 01:45:02 am »
So I fixed the fuel line it took hours to find an old 90 suburban down here in houston at junkyard but now I have another problem an elictrical problem it smeells really bad like burnt wire  I think the line shorted out on a wire it looks burnt or it got burn in half
 Pls help if it wasnt for yall I would be shoot out of luck these old trucks
Offline jaime
« Reply #5 on: January 17, 2014, 01:57:44 am »
« Last Edit: January 17, 2014, 07:04:46 am by jaime »
Offline jaime
« Reply #6 on: January 17, 2014, 06:56:15 am »
When I was replacing it I didnt c any wires in there close to the line any suggestions
« Reply #7 on: January 17, 2014, 09:38:41 am »
     If you can tell us where the wire came from and goes, we can tell you what system it is for and probably why it could have shorted out.
     For a wire loom to short out like that and burn all the way through, most of the time it is from a direct short in that system and the wire could not handle the heat of the amps being pulled through the wire.  The wire heats up beyond it's capacity and melts.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #8 on: January 17, 2014, 07:36:57 pm »
That burnt thing looks like a hose to me. See the crimped fitting where it turns to what appears to be steel tubing?
« Reply #9 on: January 17, 2014, 08:07:28 pm »
      Now that I took a closer look it does look like some kind of hose.  Jamie is that braided hose of some sort that burned in half ?  I wouldn't think it was metal braided the way it burnt, but it is too black to see clearly.
« Reply #10 on: January 17, 2014, 08:55:40 pm »
WOW!  That burned/melted TBI fuel hose caused quite a leak!  Check and service all of the engine, frame and cab grounds!  The engine may have grounded through the metal braid of the hose.  You definitely don't want that to happen again!  You may not be so lucky next time!
« Reply #11 on: January 17, 2014, 10:39:54 pm »
i wana say that was just the fuel leak. if it was burn that bad it would of sparked and we all know what happens when you have fun with fuel and spark. i think he just smalls the burn wire. hasnt found it yet
« Reply #12 on: January 18, 2014, 08:39:16 am »
Yeah Irish, you'd think that sufficient heat to 'burn' that hose would have resulted in combustion.  Yet the OP stated it appears burned.  It would have been interesting to see the hose in situ, before it was removed, to determine the actual cause of failure (e.g., abraded, torn, over flexed, too tight a bend, crushed at some point in its life, or just lining deterioration, ?).  I think a fuel hose that grossly damaged is a source for concern until the cause is reasonably ascertained.  But, that's just me expressing concern for recurrence.  As you implied, fire and fuel don't mix!
« Reply #13 on: January 18, 2014, 10:52:45 pm »
i could understand it leaking by a crack or hole. but my mind is telling me it got damaged in removal, but i could be wrong wont be the first lol
Offline jaime
« Reply #14 on: January 26, 2014, 12:35:46 am »
Sorry I was away for so long  ive been working  overtime the night befor the leak I drove the truck atleast 60 to 80 miles git home fine parked it inside garage the next day turned her on let her warm up cam back out to garage and noticed it was leaking bad  but I looked at the line and examined it and I think it just rusted threw it looked like it was kinda burned but who knows these old trucks r sometimes a big head ache
