Author Topic: adding an aftermarket fuel gauge  (Read 6381 times)
Offline guinelle1
« on: January 15, 2014, 04:29:14 pm »
i have a 79 k20 with an oem tank on the passanger side. the truck is stripped and set up for mud drags.. when i got it none of the gauges in the original cluster worked, and the fuel gauge would move with the turn signal lol... i tried another cluster and no go. is the sender on these trucks 0-90 ohm? i couldnt find much surfing online. i tested my sender and it seems to be working.
Re: adding an aftermarket fuel gauge
« Reply #1 on: January 15, 2014, 08:24:08 pm »
     http://forum.73-87chevytrucks.com/smforum/index.php/topic,16071.0.html
     Yes, most stock fuel gauges are 0 - 90'ohms.
« Reply #2 on: January 15, 2014, 09:22:28 pm »
i have a 79 k20 ...and the fuel gauge would move with the turn signal lol...
Check all of the vehicle grounds, especially the instrument cluster, cab and bed grounds.
Offline guinelle1
« Reply #3 on: January 16, 2014, 07:04:24 am »
ill check the grounds but im gunna order the aftermarket gauge
Offline 75gmck25
« Reply #4 on: January 16, 2014, 05:27:51 pm »
If the turn signals make the fuel gauge flip back and forth, its almost always the main instrument panel ground.  There should be a black wire from the cluster grounded to a post on the emergency brake mechanism (which then grounds it to the body).
Bruce
Offline guinelle1
« Reply #5 on: January 16, 2014, 07:02:26 pm »
wow thanks for all the responses ill make sure to check that ground. great community on here  :)
Offline rich weyand
« Reply #6 on: January 16, 2014, 07:11:33 pm »
If the ground isn't right, the aftermarket gauge won't work either.
Offline guinelle1
« Reply #7 on: January 16, 2014, 07:37:58 pm »
i would end up bypassing all the factory wiring, because i have no idea if any of it is any good.
