Author Topic: 1/2 studs on 6 lug front axle  (Read 4230 times)
Offline rusty_but_trusty_86
  • mudder on high school budget
« on: January 16, 2014, 09:41:18 am »
does anyone know the part number or where to get 1/2" front wheel studs for the 6 lug front axles instead of the crappy 7/16" studs? My girlfriends truck is running 36" super swampers and is snapping the 7/16" studs like nothing. I know for a fact that it is possible because i have the same exact truck as her (same year and model, both 1/2 tons) and have the six lug front axle, and mine is running 1/2" ARP hardened wheel studs, i just dont know where to get em. any help is greatly appreciated. thank you
ashes to ashes...dust to dust... if it weren't for your ford...my tools would rust!
Offline dvdswan
Re: 1/2 studs on 6 lug front axle
« Reply #1 on: January 16, 2014, 11:12:57 am »
did you try summitracing or jegs?
« Reply #2 on: January 16, 2014, 08:22:38 pm »
     Do a google search.  I just found about 6 different sources, you will have to put in your info on your truck and see which one's you want.
« Reply #3 on: January 16, 2014, 11:00:12 pm »
i cant say for sure what stud size my buddy has but before i gave him a set of ¾ ton axles he had ½ ton on his k5 with 36" and after thoses got slashed he put on 38s" and those 38" got put  on his 89 k1500 once he got the ¾ ton axles under the k5. didnt have a problem with studs, matter of fact he was mudding with 4 lugs on the ¾ ton with 44" for some odd reason
