Author Topic: Replacement External Electric Fuel Pump  (Read 7127 times)
Offline ullearn
  • 56 Chevy on a 76 Blazer
« on: January 19, 2014, 09:25:15 pm »
Getting the truck closer to running, but needing a replacement electric External fuel pump.  The one currently on it is a Walbro 12v2401 and now days it's replaced by a newer model but a bit pricey for it in the $150+ price range plus all the listed replacement models either don't seem to exist or just as pricey.
Is there a cheaper replacement model that can be found at the local auto parts store or Amazon?
12 volts
4-7 psi
20+ gph
Truck - 56 Chevy 3600 / on 76 Blazer with BB V8 454 4bbl carb and a keg for a fuel tank
Re: Replacement External Electric Fuel Pump
« Reply #1 on: January 19, 2014, 10:59:04 pm »
     I just checked my local O'reilly and they range from $52.00 to $500.00 for a holley high performance that will work for you.
     Do a search online, they are plentiful.
Offline ullearn
« Reply #2 on: January 20, 2014, 10:03:05 am »
How important is it to stick to the GPH and PSI specs of the old pump? As I am seeing them range quite a bit.
« Reply #3 on: January 20, 2014, 07:21:00 pm »
     If this is fuel injected then not much, if it is not then it is important, too much pressure with nowhere for it to go could build and burst a hose.  I believe, depending on the fuel hose you use, the burst rating for most fuel hose is around 300 psi.
Offline ullearn
« Reply #4 on: January 22, 2014, 11:52:38 am »
yeah it's a 500cfm edelbrock carb so looks like it needs a 4-6.5psi fuel pump and others have been recommending a fuel pressure regulator as well since they say those pumps rated 3-7 really put out 8 and the pressure could blow past the needle seat.
I decided to tear down the old fuel pump just to see, and found that the bellow in the old pump had melted into tar, so found a cheap rebuild kit online and going to give that a shot for $14 and hopefully some savings.
If that doesn't work well hopefully I learned something in the mean time versus just buying off the shelf again like I did with the starter (in my defense the starter was really cheap though).
Offline ullearn
« Reply #5 on: March 09, 2014, 12:00:12 pm »
I ended up going with this nice little quiet cheap unit from Amazon; Autobest F4023 same as an Airtex E8012S
http://www.amazon.com/Autobest-F4023-Electric-Fuel-Pump/dp/B00496Z3FS/ref=sr_1_1?m=ATVPDKIKX0DER&s=automotive&ie=UTF8&qid=1394382960&sr=1-1&keywords=autobest%20F4023&tag=vglnk-c299-20
http://www.rockauto.com/catalog/moreinfo.php?pk=293410
Word of warning, don't over-tighten the filter onto the pump as it breaks the crimped seal of the filter and causes leaks (thankfully easy shipping/returns with amazon prime).
