Author Topic: Rear End Bearing ID  (Read 3199 times)
Offline COEBill
Rear End Bearing ID
« on: January 21, 2014, 08:20:14 am »
Hi Guys
Can anyone tell me the Bearing Numbers for my 1974 C30 14 Bolt Rear Axle Centre with 4.10 Ratio?
I was going to try and buy a Bearing Kit from the US, but a $100 freight bill just put them out of my reach.  So I will try and get them here in Oz, but nobody has listings for Chevy Trucks, honest !!
If someone could tell me the Bearing numbers that would be a big help.
The Rear Axle is still complete and running but the bearings need replacing, so I would like to get everything before I tear it down.
Regards
Bill
« Last Edit: January 21, 2014, 09:28:56 am by bd »
Offline rich weyand
Re: Rear End Bearing ID
« Reply #1 on: January 21, 2014, 09:25:35 am »
Here's what I get from the 1973-1978 parts book for a 1973 corporate 14-bolt:
Bearing, Rear Wheel Outer  GM 7451812
Bearing, Rear Wheel Inner  GM 7451928
Bearing, Diff. Side  GM 7451928
Somebody who's torn one down, does that jive that the bearings on the diff side and the wheel side of the half axles is the same?
Offline COEBill
« Reply #2 on: January 22, 2014, 02:28:40 am »
Hi Rich
        Thank you for that information, you wouldn't have the Pinion Bearings listed as well would you.
Interesting that the Side Bearing are the same as the Axle Bearings, Hmmm
Regards
Bill
Offline rich weyand
« Reply #3 on: January 22, 2014, 08:27:27 am »
Bearing, pinion, front  GM 7451155
Bearing, pinion, inter  GM 7451888
Bearing, pinion, rear  GM 7451870
Here is the reference drawing.
