Author Topic: FRONT DROP SHOCKS NEEDED?  (Read 4891 times)
Offline bicent truck
« on: January 01, 2007, 12:05:00 pm »
On a 2 and 1/2" front drop using spindles, is it true you do not need drop shocks because the spindles do not alter original geometry of suspension only needed when using coil drop springs. Shouldn't matter but I'm doing a 4 inch on the rear. One more question, can I get spring shims to align driveshaft for the rear at any auto parts store? Thanks
Offline roundedline
Re: FRONT DROP SHOCKS NEEDED?
« Reply #1 on: January 02, 2007, 05:01:00 pm »
drop shocks
« Reply #2 on: January 03, 2007, 03:43:00 am »
I'm sorry, Chris -Yes I DON'T need them in answer to my question, or yes I DO need the drop shocks with spindles only?
Offline roundedline
Re: drop shocks
« Reply #3 on: January 03, 2007, 01:50:00 pm »
Sorry about that...  The dropped spindles don't require dropped shocks.  You can use good stock lenght shocks.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
