Author Topic: need lbs to torque upper control arms  (Read 5699 times)
Offline shaved80
« on: January 07, 2007, 04:33:00 pm »
i replaced the L shaped piece that's on the front crossmember, and it holds the upper control arm. yes, the one that is riveted to the crossmember. how tight should i torque down that piece to the frame? there are 4 bolts. and how tight should i torque down the upper control arms?
Offline roundedline
Re: need lbs to torque upper control arms
« Reply #1 on: January 08, 2007, 08:38:00 am »
For the upper control arms they are 70 ft.lbs.
On the control arm bracket, I would probably have welded it back on, but...  I would say as tight as you can get it with some High strength bolts, 90ft.lbs maybe.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline shaved80
« Reply #2 on: January 08, 2007, 10:54:00 am »
i meant the 4 bolts that hold it in from the factory, the ones against the frame not the crossmember
Offline roundedline
« Reply #3 on: January 08, 2007, 02:27:00 pm »
I run them in with an air impact roughly 120ft.lbs.  Or tight
Project Su
Jimmy 2WD Project
