Author Topic: MPG of a 78 K10 350/4spd and a 3in lift kit w/31s  (Read 4808 times)
Offline BANova73
« on: February 05, 2014, 03:29:55 pm »
Im wondering what kind of MPG I could expect to get out of a 78 K 10 with a 350/4speed and a 3 inch lift kit and 31-33in tires gets and how i could increase the gas milage
Re: MPG of a 78 K10 350/4spd and a 3in lift kit w/31s
« Reply #1 on: February 05, 2014, 05:09:04 pm »
Anything that takes a truck away from stock is going to negatively effect the mpg.  Stock size tires and height along with modest driving habits would be your best bet.  A proper tune to assure your engine is running at peak efficiency is also key to decent economy.  To many variables to even venture a guess...
« Reply #2 on: February 05, 2014, 11:09:56 pm »
4 speed as in a sm465? you could increase the millage by towing it behind a cummins
keep it under 60 and dont take off so fast. i would imagine you have 3.73 gears in the axles so im kind of curious on your millage also
Offline ehjorten
« Reply #3 on: February 06, 2014, 01:52:16 pm »
I average 8.7 mpg in my '77 K20 with 31" Toyo Open Country M/Ts.  THM350 automatic.  The suspension is stock with a Part-time conversion on the NP203.  It has 4.10:1 rear gears.  Best I have got is 9.9 MPG and worst is 7.5 MPG
The engine needs a good rebuild as it has many miles on it and the Holley carb is junk!  I have a new SM Quadrajet to put on it and a new intake, but it is a Vortec manifold and I need to get me some Vortec heads to go with it and then actually rebuild the engine!
« Last Edit: February 06, 2014, 01:55:42 pm by ehjorten »
-Erik-
« Reply #4 on: February 06, 2014, 11:17:46 pm »
to add to the milliage question i have a 350 sm465/205 4.10 with my  hummer tires 37.5x12.5r16.5 i get 9 MPG. with my 38x16x16 swampers i was getting 7-8
