Author Topic: Motor swap help  (Read 4380 times)
Offline Lowhoe775
Motor swap help
« on: February 08, 2014, 05:24:50 pm »
1978 c10 Scottsdale short bed. It currently has a inline 6 250. With a automatic 3speed. My friend is selling me a 305 with a 200r4 trans. It is coming out of a 1986 Oldsmobile cutlass. I'm going to see if it runs it should though. But my question is this worth the time to take out and put in my truck. I know it will get better fuel milage than that 3 speed I have. And if it's worth it what would I need to know on how to hook it up on the truck if there is any topic or forum out there that has step by step or even some words of advice will help thanks
Offline Stewart G Griffin
Re: Motor swap help
« Reply #1 on: February 08, 2014, 07:30:16 pm »
What rearend gear do you have now?
Offline HAULIN IT
Re: Motor swap help
« Reply #2 on: February 09, 2014, 12:08:57 am »
Low, That is NOT a 305! It is likely a 307, but could also be a 260. What you have there is a true Olds based engine, not a Chevy based small block like the 305.
As to: "Is it worth it?"...That I guess is up to you & why your wanting to do it. If your 6 cyl. is damaged & you need an engine to make the truck go, it would be an Ok plan assuming it hasn't sat forever not running. For the most part...I'd say No, it's not worth the bother.
Now on to: "What do I need to know to hook it up?"...That really isn't too bad, however there is some things you need to know. The Olds has a different bolt pattern on the bell housing so you need to use both (engine/trans) together as a unit or purchase an adapter plate if for some reason you decide to only use the engine or the trans with one from your truck. Fairly simple fabrication is needed on the motor mounts to bolt it in the truck. The basic wiring from your truck will work...you will need to alter the lengths on a few wires & re-route them. The driveshaft will be too short. You will want to acquire a non-spark control distributor & carb from an older Olds engine to eliminate the computer control that is on the engine (assuming it hasn't been done already to the Cutlass). The rest of it is pretty straight forward...exhaust, rad.hoses, gauge sensors, accessory stuff is all doable. If you decide to go ahead with it, let me know. I should be able to answer any specific questions that you may have. Here is a basic picture of the motor mount plates to get it mounted in there. Lorne
Offline Lowhoe775
Re: Motor swap help
« Reply #3 on: February 09, 2014, 03:42:13 pm »
that I do not know. It's bad on the high though. So it's just a street cruiser
Offline Lowhoe775
Re: Motor swap help
« Reply #4 on: February 09, 2014, 03:50:10 pm »
thanks a lot for the advice. I originally want a 350 chevy small bock. I just want a little more kick out of an engine. That inline 6 is great no problems and it has 68,433 original miles. But I don't think I'm going to swap it. It's reliable right now. But I will let you know if I do go through with the olds engine.
