Author Topic: Hey just curious  (Read 4198 times)
Offline scoob4444
Hey just curious
« on: February 12, 2014, 01:40:25 am »
How many degrees should my vacuum advance, advance the spark on a 350?
Sent from my XT1080 using Tapatalk
Re: Hey just curious
« Reply #1 on: February 12, 2014, 04:27:47 am »
it should be only 20° so lets say you set your timing at 16° your advance should be 36°. now not all advances are the same stock is different than aftermarket and 20° should be stock
You want 36* of advance at 3000 rpm with the vacuum advance disconnected.  For stock distributors, this should 16* at idle with the vacuum advance disconnected.
Offline scoob4444
« Reply #2 on: February 12, 2014, 03:54:06 pm »
Why thank you
Offline Stewart G Griffin
« Reply #3 on: February 16, 2014, 09:41:24 am »
These are some very good papers on timing, ignition etc.:
http://www.digitalcorvettes.com/forums/showthread.php?t=75830
