Author Topic: truck has no dome light  (Read 16365 times)
Re: truck has no dome light
« Reply #15 on: February 18, 2014, 07:42:22 pm »
Those holes are from something the previous owner did.
Adding a headliner won't help with the dome light, you still need to cut a hole.
Offline winky
« Reply #16 on: February 19, 2014, 06:49:21 pm »
here you go! :)
held the light up so you can compare it to the hole. i would probably cut the hole just a little bit bigger then the recessed part of the light and then just use self tapping screws to attach it (make sure there not too long of course) if you need anything else let me know like i said i have a few of these trucks threw out the year models so i usually can get pics info etc hope this helps you out,
Offline 75_chevy
« Reply #17 on: February 19, 2014, 07:31:16 pm »
SWEET YES THANK YOU!!!
« Reply #18 on: February 20, 2014, 07:28:32 am »
     75_chevy, the pic of your visor! I do not see any holes.  If you are wanting to mount a dome light, the first question should be is, do you plan or want to install a head liner in your truck ?
     Regardless you will have to get wires up to the light, that means going between the 2 pieces of roof metal or running behind headliner and door post moulding if equipped or installed.
     I am thinking of something like this,
     http://www.jcwhitney.com/dashtop-highliner-headliner/p2023838.jcwx
 It has a dome light built right into the middle.
Offline 75_chevy
« Reply #19 on: February 20, 2014, 03:36:30 pm »
I would like to put one in in the future but for now I'm just going to drill some holes and mount this dome light I got.
here's some more pics of the holes above the visor
« Reply #20 on: February 20, 2014, 11:42:30 pm »
     On my 74 it has 3 holes there where the rear view mirror was mounted at one time.  I am not sure what those 2 holes would have been for.
Offline roger97338
« Reply #21 on: February 21, 2014, 08:06:55 am »
If you don't feel like cutting a hole in your interior roof (and I wouldn't blame you.) you could disconnect the wires for the overhead dome light, and install or repair your floorboard dome light. Does your truck have the lower dome light? It's under the dash a little bit to the passenger side of the ash tray, if I remember right.
Offline roger97338
« Reply #22 on: February 21, 2014, 08:46:01 pm »
I wonder if those two holes above each sun visor are from previously having a panoramic rear-view mirror installed sometime in the past.
Offline 75_chevy
« Reply #23 on: February 21, 2014, 09:13:54 pm »
is that how they mount? I like those things
« Reply #24 on: February 22, 2014, 09:40:48 am »
     The mounting holes for those are usually father apart.
Offline roger97338
« Reply #25 on: March 01, 2014, 03:00:45 pm »
     I just did a Google image search, and you're absolutely right. Those mirrors attach way farther out.
     Looks like I was wrong. See above.
     I like those mirrors, too. I've not seen them very often any more, and kind of forgot about them.
