Author Topic: Axle swap  (Read 10602 times)
Offline chevyride
Axle swap
« on: September 26, 2006, 10:07:00 pm »
I have a 1979 k10 4x4 shortbed that I am building. I recently bought a 1981 3/4 ton longbed. I would like to put the 3/4 ton axles under the 79. Will I have to make any modifications or will the 1981 3/4 ton axles bolt directly to my 79? Also the 79 has a 12 bolt and the 81 has a 14 bolt (9.5 ring gear). Will this cause any problems?
Thanks, Dustin
Offline roundedline
Re: Axle swap
« Reply #1 on: September 26, 2006, 10:07:00 pm »
Yoke/driveshat will be different on the axle side for the 14bolt.
Front should be a 10bolt for both.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Swallie
Re: Axle swap
« Reply #2 on: December 07, 2006, 04:20:00 pm »
they make a u-joint so you can use a 1/2 ton drive shaft on a 3/4 ton rear end....other than that its a direct bolt in....
Offline joesgarage71
  • Wrench
Re: Axle swap
« Reply #3 on: December 11, 2006, 02:49:00 pm »
That be 1330 Joint(1/2 ton) to a 1350 Joint(3/4 ton) Conversion.
