Author Topic: inner fenders  (Read 5372 times)
Offline 87V20Kansan
inner fenders
« on: February 22, 2014, 10:25:21 am »
Can anyone tell me if it's possible to get the front inner fenders out without removing the front fenders? Mine are rotted as most are and I need to replace them.
Cecil: 1987 V20, TBI 350, TH400, 4:10's, 7" lift, 37" H1 beadlocked runflats. Cummins swap someday.
Offline LTZ C20
Re: inner fenders
« Reply #1 on: February 22, 2014, 10:48:57 am »
Yes it is. Just undo all the bolts along the front, back and sides. Also remove anything bolted to the top side of the inner fenders under the hood, i.e. bottle jack, tire tools, windshield washer fluid bottle, battery tray. Then if everything is disconnected, with some wiggling it should just drop down over the tire, then just roll it out. Might have to roll the front or back half out first then the other side. It's pretty easy tho, I've done it a couple times.
LTZ Cheyenne C20
Re: inner fenders
« Reply #2 on: February 22, 2014, 11:14:30 am »
     Depending on tire size, you might have to jack each side up a little to give your self more room.
Offline 87V20Kansan
Re: inner fenders
« Reply #3 on: February 22, 2014, 11:31:23 am »
Cool thanks guys. With 37's on it I think I'll just pull the wheels off and set it on jackstands.
Re: inner fenders
« Reply #4 on: February 22, 2014, 09:35:11 pm »
     Probably a good bet.
Offline LTZ C20
Re: inner fenders
« Reply #5 on: February 23, 2014, 01:11:27 am »
Sounds like a plan!
LTZ Cheyenne C20
Offline 22hornet
Re: inner fenders
« Reply #6 on: February 26, 2014, 07:43:15 pm »
Are you using new inner fenders and if so where did you get them from. Thanks Jim
Offline winky
Re: inner fenders
« Reply #7 on: February 26, 2014, 09:45:53 pm »
great idea lol. i tried this with 37's it was so close to coming out that i fought with it for 30-45 mins before i finally gave up and took the wheel off
Offline 87V20Kansan
Re: inner fenders
« Reply #8 on: February 27, 2014, 08:26:03 pm »
Yes sir Jim. You can buy them for this website's store and have them shipped to you! I live in the KC area and two certain "well advertised" truck parts warehouses are right down the street, relatively speaking. These happened to come from the one you see the most on T.V.
« Last Edit: February 27, 2014, 08:30:17 pm by 87V20Kansan »
