Author Topic: Front Crossmember  (Read 4803 times)
Offline Pushrod
Front Crossmember
« on: March 20, 2007, 06:36:00 pm »
Are all C-10 front suspension crossmembers the same from 73 to 87? Also, is there any difference in the upper/lower control arms and ball joints between the 1" and 1.25" rotors/spindles.
I'm lookin forward to pickin one up in the near future to rebuild and modify.
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
Offline roundedline
Re: Front Crossmember
« Reply #1 on: March 21, 2007, 02:11:00 pm »
73-87(91) are the basically the same.  I think the stamping on the UCA and LCA changed alittle, but they use the same pieces.
Control arms on the 1 vs 1.25 are the same, the difference is the spindle.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline Pushrod
« Reply #2 on: March 22, 2007, 10:34:00 pm »
Good info, Thanks fellas!
