Author Topic: deleting smog pump  (Read 3975 times)
Offline 75_chevy
deleting smog pump
« on: February 24, 2014, 04:33:31 pm »
anything I need to keep in mind while doing this? already got a smaller belt of course. thanks
Re: deleting smog pump
« Reply #1 on: February 24, 2014, 06:15:46 pm »
      If I remember right you are in CA. correct ?  The good news is yours is a 75 so you do not have to worry about smog.  I would make sure everything is plugged properly at both ends that you take off, ( and take off the bracket, so it is not visable that you took off the smog pump if at all possible ), and do not throw away any of the parts you take off, you never know with Ca. when things could change for our trucks in regards to the law.
Offline 75_chevy
« Reply #2 on: February 24, 2014, 06:58:08 pm »
thanks bake and yes u are correct about the CA. yes I will be keeping them for sure, we will probably be using it in our 78 trans am we're putting a new motor in but will still require smog. hopefully they don't make us require smog in the future I'll be skrewed
Offline 75_chevy
« Reply #3 on: February 24, 2014, 06:58:31 pm »
« Reply #4 on: February 25, 2014, 07:53:53 am »
     Can not even tell if it was ever there.  Looks good.
Offline Senck243
« Reply #5 on: October 26, 2014, 09:07:48 am »
How about deleting this on a tbi? Will it make it run worse?
Sent from heck
1984 k10 305, sm465, np208
