leaf spring bushing question
Topic: leaf spring bushing question (Read 5996 times)
81GMCBILL
March 04, 2014, 08:48:24 pm »
I am ready to install new leaf spring bushings, but was wondering if you smear a light
coat of grease or ? on them before installation. Or do you install them dry -without anything?
85 GMC K25 4X4 383/th400/np208
Re: leaf spring bushing question
March 04, 2014, 09:02:52 pm »
What kind of bushing? Rubber, Urethane, Poly?
81GMCBILL
March 04, 2014, 09:12:42 pm »
there poly-urthane.
March 04, 2014, 09:15:22 pm »
they should have came with instructions on what to use with them.
bd
March 04, 2014, 09:52:13 pm »
Formula Five Prelube
81GMCBILL
March 04, 2014, 10:21:19 pm »
thanks - for the help - BD - I see what to use - I was just trying to make sure I
have everything like this lube before I get the bushings, like Capkaos said - the instructions
will probably tell me what to use.
bd
March 04, 2014, 10:48:55 pm »
If you're purchasing a bushing set, it will likely come with lube.
March 05, 2014, 01:49:20 pm »
Ah so you haven't gotten them, if it requires anything special it should come with them unless it is something easily obtained...
March 06, 2014, 11:59:40 pm »
Quote from: bd on March 04, 2014, 10:48:55 pm
when i put in one of my lift kits we used a c-clamp to squeeze the bushings in the eyes of the springs also
81GMCBILL
March 10, 2014, 10:44:03 pm »
yea - they fit easily into the front leaf spring eye- but I noticed they will be needing quite
a bit of force to install on the rear frame mount part of it(where the top-shackle connects).
I was thinking like you said (IRISH-Alley) to use a c-clamp or a ball joint clamp I have.
