Author Topic: 350 Heads  (Read 15531 times)
Darren C20
  • Guest
350 Heads
« on: July 31, 2002, 12:11:00 am »
I have a 1976 C-20 with a stock 350, just curious what heads are on it right now? also pistons, and the stroke, bore, compression, etc.  Thanks for any info.
Offline bored and stroked
« Reply #1 on: August 01, 2002, 01:27:00 am »
Pull of the valve coers and get the numbers stamped on the heads. Then look at the block behind the drivers side head and get the numbers back there. Finally go to www.mortec.com and look up those numbers to see what you have.
Offline ChevyGuy
hmmm
« Reply #2 on: August 05, 2002, 05:17:00 pm »
Most likely 882's.
82ChevySWB4X4
  • Guest
Re: hmmm
« Reply #3 on: August 31, 2002, 10:14:00 am »
Anyone know where I can find a good set of 461's?
