Author Topic: defroster vents  (Read 5046 times)
Offline Sprinkler-Man
  • 80 GMC Sierra Classic 4x4
defroster vents
« on: March 16, 2014, 10:08:54 am »
I can't seem to get any air out of my defroster vents I am not sure why...any help?  My blower sometimes doesn't work when I switch the selector from heater to vent.  Do I need a new selector panel or a new blower switch?  My truck has factory air.
Thanks
Re: defroster vents
« Reply #1 on: March 16, 2014, 11:59:18 am »
      I assume it is an 80 truck that we are talking about since you did not say and that is what is in your screen sign in ?
      Have you checked your cables that go from your dash mounted selector to the heater/AC box under the dash to verify they are working and moving ?
      If so then you will need to move in to the inside of the box to see if the flap door is moving.  Also I do believe, I might be wrong though, that your truck should have both mechanical and vacuum controls for the heater/AC.
Re: defroster vents
« Reply #2 on: March 16, 2014, 08:11:13 pm »
1980 GMC Sierra Classic.  I have taken out the main ducts to the dash vents to get a better view.  There does seem to be 4 vacume lines running to the vents but i cannot find the one that controls the defrosters.  I will look more once it heats back up and I run the truck again.
Re: defroster vents
« Reply #3 on: March 16, 2014, 09:41:57 pm »
     Go to the tech section and look up the service manual for your truck, it should contain a breakdown and appropriate diagrams.
