Engine/Drivetrain
Head question, best factory heads
Topic: Head question, best factory heads (Read 16958 times)
travisr1988
Re: Head question, best factory heads
Reply #15 on:
April 09, 2014, 05:20:41 pm »
okay guys, I actually got my tax return that I didn't expect(long story). So I will be going with vortec heads...my brother can get them at 20% off of $299 each. I will be using a JEGS vortec/carb intake with an adapter for the TBI and Lunati Voodoo cam. So that's sorted out, now for exhaust, fuel lines, fuel pump, floor pans, rear tires and tail lights to get it road worthy.
heads are Spartan/ATK
intake:
http://www.jegs.com/i/JEGS+Performance+Products/555/513002/10002/-1?CAWELAID=1710856258&CAGPSPN=pla&catargetid=1808722425&cadevice=c&gclid=CImBje6ivb0CFeMF7AodOzYAPA
cam:
http://www.lunatipower.com/Product.aspx?id=1982&gid=287
213/219 @.050 256/262 Adv. .454/.468 lift 112LSA 108ICA
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
BADAZ chevy guy
Chevy! My drug of choice!
Reply #16 on:
April 09, 2014, 06:32:27 pm »
Are the heads machined for the higher lift on the cam? Vortec heads will only go .420 to .460 lift.
CAUTION! Do NOT open vent wing if speed is above 130 MPH!
My build threads:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28250.msg235337#msg235337
http://67-72chevytrucks.com/vboard/showthread.php?t=624182
travisr1988
Reply #17 on:
April 14, 2014, 03:35:41 pm »
I have a question about the tbi...will i need a tune or does the ecm make necessary changes to accomodate the heads and cam?
Reply #18 on:
April 15, 2014, 06:55:20 pm »
If it is the factory TBI ECM you will need a chip burned for the changes
travisr1988
Reply #19 on:
April 16, 2014, 04:37:42 pm »
Who knew an engine build could be so frustrating? It was supposed to be a simple build...fix whats broken, change the cam and done. Then my dad decided we're adding tbi...which meant a different cam choice and wiring and new fuel lines and pump. Then when we looked at the old heads we found they need a valve job so he decided i'd buy new heads...350 tbi heads...which i don't think will satisfy me. I talkes to him about it and he told me its tbi heads or smog heads. I want vortecs, since i got my tax return he gave me the okay for vortec heads. So i ordered vortecs...now my brother tells me my dad is mad at me for ordering vortecs and that it'll cost atleast $400 more to use vortecs over tbi heads. I'm tempted to forget about the tbi since what i have is from a 305 and use the quadrajet i already have. Oh and he insists on using egr and vapor canister and all the other ugly smog stuff which of course i would have to buy because my truck has none of it. Yet his truck doesn't have any of it...just a $1600 short block with summit camel hump heads a cam thats too big rpm air gap intake quadrajet and headers (which he is dead set against my truck having because it doesn't need them). My truck is being built to be a daily driver that i can take to meets and run at the strip everyone once in awhile and enjoy...something fun to drive...not something just to drive from point a to point b. It's my hot rod...not his restoration...if i were gonna restore it i would leave the 6 in it and make it 100% stock.
SomeTexan
No such thing as too much hp
Reply #20 on:
April 16, 2014, 05:20:31 pm »
If its your truck and your money, do what you want. Personally, I wouldn't even bother with a small block, swap in a 5.3/4l60e. Then you have an easy 300+hp, overdrive and 20+ mpg with a stock 5.3.
86 swb c10, LQ4/glide with 80mm turbo
Engine/Drivetrain
