Author Topic: Cam Shaft  (Read 25246 times)
Offline ckuper
Cam Shaft
« on: March 21, 2002, 12:42:00 pm »
hey i just got some work done on my truck and i just wanted to know how much trgue i gained by putting a towing cam. thanks
Offline 76chevyman
Re: Cam Shaft
« Reply #1 on: March 27, 2002, 10:02:00 pm »
Depends on what type of cam. We need to know at least what kind it is. Part number??????
Most towing cams or truck RV cams are melling mtc-1. Melling MTC-1 cams are the most common replacement RV cam put into trucks and theres a good reason, They rock! These cams are highly underrated meaning they have low duration and lift numbers but in a stock headed engine they live quite well and produce around 30hp more than stock.
76 Chevy Pu Custom Deluxe C10, light green.Came home from the hosptial in it.O.E 160HP 350, Muncie HD 3 speed on the tree 3.73 rear end C.A special, emmissions equiptment Unleaded gas version.Now med firemist blue and sports a  355 86 M block from a school bus, 440HP  460TQ crank HP&TQ.58cc heads, 1.94in., flat top pistons Manley aluminum 5.7 rods, comp 270H cam, weiand xcellerator med rise intake holley 4160 carb accel blue print distributor & extrenal coil, flowtech headders, dual 2.5 exhuast 32in glasspacks 12in chrome tips, TL posi. Chrome tube grill, 82 suburban wrap bumper.Yep its very fast, runs 12.1's @ 118 @4800ft above sea level and still a 3 on the tree.  Alot more unlisted mods. truck was totally restored in 99 but I'm anal about things like dents from shopping carts aholes doors so it going to be re restored in the next few years.   A couple pics of my truck are here http://albums.photopoint.com/j/ViewPhoto?u=1760236&a=13575129&p=52415529&f=0But they are about a year and a half old and alot has changed especially under the hood.
Offline ChevyGuy
Comp
« Reply #2 on: March 29, 2002, 11:06:00 am »
Try calling Comp Cams. They can tell you what you need just by you tellin them what you want They make some good cams. I got their 280H in my truck and it makes all the torque i want. Just give em a call.
Offline RSBAD454
Re: Cam Shaft
« Reply #3 on: September 18, 2002, 11:01:00 am »
thats pretty quick for the 1/4 in a heavy truck running a small block? my truck will be in the 11'2 i guess with a 500HP 427 BB? huh
http://
Offline 87crewcab1
Cam Shaft
« Reply #4 on: September 20, 2002, 03:59:00 pm »
I have a 23 t-bucket with sml block with around 420 horse, it wieghs 1800 lbs. Itruns 6.37 in the 1/4. hehehehe then i wake up and smell the coffee.
Offline 84 silverado
bragging rights........
« Reply #5 on: September 20, 2002, 06:38:00 pm »
OK, as long as we're talking about going fast... our 2001 Firebird weighs 2280 with driver and runs 4.96 in the 1/8 with a mild spray and a 509 inch big block. Has a 1.12 60 ft.......... It'll be better next year when the 630 inch motor is done!!!!!!
Offline 79SilveradoK30
RE: bragging rights........
« Reply #6 on: September 22, 2002, 05:05:00 pm »
Holy @#%$, 1.12 second 60 foot times? That is fast, I mean really fast!!!
Offline RSBAD454
Re: RE: bragging rights........
« Reply #7 on: September 24, 2002, 09:38:00 am »
i was talking baout that truck with a 350 in it, i dont believe it runs a 12.1?
http://
bad weekend......
« Reply #8 on: September 24, 2002, 05:04:00 pm »
OK, a bad weekend at Bradenton....... the car went OK but times fell off all weekend due to weather. When it came down to it, we only went one round and the timing computer really let us down. Said we should have gone a 7.34(1/4) but we only went a 7.42...... hmmmmm, time to rethink a computer......
Offline 83CHEVY
Too dang Fast!!!
« Reply #9 on: September 26, 2002, 07:45:00 pm »
Not only 12.1, but 12.1 at 4,800 ft elevation!!!  That would correct to about an 11 flat at sea level.  Hmmmmmmmm..........Don't think so!!!
Mike
Offline RSBAD454
Re: Too dang Fast!!!
« Reply #10 on: September 27, 2002, 09:19:00 am »
thats what im sayin..............my 427 is about 500HP and my truck weighs in at 4160 with me in it. i havent ran it yet at the track, caus ei dont have the right gears and the engine only has 800 miles on it. but im guessing ill run a low 13 or MAYBE a very high 12. a 350 thats mild in a heavy truck i doubt runs deep 12's at almost a mile high? no way jose.
http://
Offline bored and stroked
« Reply #11 on: October 11, 2002, 05:41:00 pm »
Did you guys check out the entire sig? 440hp and 460lbs/ft with a 1.94 intake valve? Not going to happen. 58cc chambers? Sounds like a 305 head to me, not even close to being able to support 440hp with a 1.94 intake. A comp 270H cam? Even with AFR heads with 1.94 intakes that cam will not make that much power from 350cid. 3 on the tree? YEAH RIGHT! I hate people that run sh*t out of their mouth.
My muncie 4 speeded, 383 with vortec heads, 10:1 compression, comp 280H cam, 750DP'd  78c10 makes 413hp and 430lbs/ft and will only run in the mid 13's if I got perfect traction.
Offline LOHRTBT
lol!!
« Reply #12 on: October 13, 2002, 08:25:00 pm »
Ummm........NO!
haha! Did tim come back as another person?? hehee
GRAMPS
  • Guest
Tune UP
« Reply #13 on: October 18, 2002, 05:53:00 pm »
HI--I have a CHEVY & I Installed new Gears & Timming Chain-& had the Carb rebuilt-& All nw Wires -plugs & points-    My Problem?? Is It has NO POWER?        it Runs Preety GOOD! afte It warms UP!    BUT--I must have Screwed UP?? Some Where?? AS It should RUN a lot BETTER? I Think?   Any Suggestions??                 THANKS from an OLD 68 yr Old MAN1      That just Wants His Truck to RUN GOOD!                  JOE
Offline 83CHEVY
Lack of power
« Reply #14 on: October 19, 2002, 09:52:00 am »
Are you experiencing black smoke before it warms up?  From the work you did, it sounds like a choke  adjustment problem.  If your choke is set too rich (closed too far), you will get black smoke until it warms up.  I suppose that it could be open too far also, meaning it would be too lean until it warmed up, but you would probably get a backfire through the carb or something with that problem.  Check the choke first.  A timing problem should not get better after warming, so I don't suspect that.
Mike
