Author Topic: Dakota Digital  (Read 6532 times)
Offline chevyjoe_99
Dakota Digital
« on: March 22, 2014, 06:50:42 pm »
I am wondering if anyone has installed the gauges on a truck that has dual fuel tanks? The manual says to run two wires to the sender and I'm not sure the easiest way to hook it up to switch tanks with the dash mounted tank switch. Any help would be appreciated.
'80 K25 High Sierra, 7" lift, 36x14.50R16.5 Swampers, mildly built 400 small block, sm465 4spd
Re: Dakota Digital
« Reply #1 on: March 24, 2014, 09:36:26 pm »
There is only one fuel sending wire, when the tank switches it just changes to the other one on the back side of the switch.  You only need one wire under the dash to the cluster to the Dakota box.
Re: Dakota Digital
« Reply #2 on: March 24, 2014, 09:51:04 pm »
     Hey Capt. curiosity just got the better of me.  I just went through all the wiring diagrams for 77 - 80 and found nothing showing the dual switch in the dash or the switching mechanism under the cab, did I miss something ?
Offline chevyjoe_99
Re: Dakota Digital
« Reply #3 on: March 24, 2014, 09:58:36 pm »
So I can tie into the pink sender wire ( #18 in the plug for the factory cluster) and not worry about the ground?
Re: Dakota Digital
« Reply #4 on: March 24, 2014, 10:11:43 pm »
Yes you can.  Dakota recommends running a ground wire from then sending unit lid to the FUEL - of the controller box.
Offline chevyjoe_99
Re: Dakota Digital
« Reply #5 on: March 25, 2014, 12:12:28 pm »
That's the ground I was asking about. Thanks
