Author Topic: Need opinions on fuel tank  (Read 4154 times)
Offline Mph306
« on: March 23, 2014, 04:06:15 pm »
Hey guys! New here. I've got an 86 305 4x4 4spd. I just picked it up and it doesn't have gas tanks. What would you guys suggest? I like the look of those custom ones that sit between the frame rails in the rear. Worth it? I'm a fabricator so cost would be low. Let me know what you guys think. Thanks
Offline pholliday1
  • 1990 V3500 Crew Cab
Re: Need opinions on fuel tank
« Reply #1 on: March 23, 2014, 08:50:36 pm »
Are there no gas tank parts at all? No filler necks or anything?
Offline rich weyand
« Reply #2 on: March 23, 2014, 11:58:00 pm »
I never understood the people who "for safety" replace the saddle tanks with tanks between the rear frame rails, especially on a K truck.  You are much more likely to get rear-ended than T-boned, and modern wedge-nosed cars are gonna go right under the back and rip the tank open.  A third of all auto accidents are rear-end accidents.
Just put on a saddle tank or two and go from there.  They're only a 100 bucks.  Not worth the time to fab up something.
Offline jaime
« Reply #3 on: March 24, 2014, 01:15:00 am »
It personal preference u have 4x4 so the stock replacements wouldnt be
 bad  if ur fuel pump goes out u can drop tank easily  compared to a lower truck
Offline Mph306
« Reply #4 on: March 24, 2014, 08:30:16 pm »
Cool thanks guys. I think I'll just go with stock tank(s). What's the biggest available? I don't have anything from fuel lines under cab back. So I'll need filler necks, fuel sending units.. Anything else I would need?
« Reply #5 on: March 24, 2014, 08:53:39 pm »
Biggest you can get on a Short bed is 16 gallons, biggest you can get for a Long bed is 20 gallons.  Fillers will need to be sourced from a donor.
Offline Mph306
« Reply #6 on: March 27, 2014, 12:02:34 pm »
Upon further research I think I'm gonna go with a blazer/jimmy 31 gallon tank.
« Reply #7 on: April 03, 2014, 11:23:26 pm »
That is what is under my R10.
This is what I wrote a long time ago...  http://www.captkaoscustoms.com/blazertank.html
Same tank, different truck...  http://forum.73-87chevytrucks.com/smforum/index.php?topic=12120.msg194637#msg194637
