Author Topic: 15x5 5 lug OEM wheel specs  (Read 6132 times)
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
« on: April 02, 2014, 01:32:14 am »
I'm headed out this weekend to get my truck (Finely!) Trouble is, it won't fit on the car dolly with the tires it currently has on it. I need to find a set on stock 15" rims at the junk yard, but I don't know what the center hole size is. HELP? 1977 C10 15" w/ 5x5 lug pattern.
Re: 15x5 5 lug OEM wheel specs
« Reply #1 on: April 02, 2014, 07:16:10 am »
Don't know the spec but if you get the steel rims from a 1998 or older you will be fine
« Reply #2 on: April 02, 2014, 07:18:03 am »
1988-98 the rims are closer to the frame if that makes sense
« Reply #3 on: April 02, 2014, 09:09:36 am »
Thanks for the feed back guys. The reason I need to know the actual size is that most of the wheels in a junk yard aren't still on a vehicle. So, when I find one with the right lug pattern, I'm not sure if it came from a Chevy, Ford, whatever.
« Reply #4 on: April 02, 2014, 10:02:09 am »
The pictures is what you should be looking for.  These are off my 1992, notice you can't put a small hubcap on it.
« Reply #5 on: April 02, 2014, 11:28:38 am »
Thank you. Can you measure the center hole please? I'm not looking for the stock wheels for a resto project. I just the stock center hole SIZE so I can find wheels at a junk yard. I need to get a set of stock tires on the truck to fit the truck on a tow dolly to bring it home.
« Reply #6 on: April 02, 2014, 01:22:28 pm »
3 1/8" as close as I can measure the oblong hole
« Reply #7 on: April 02, 2014, 01:38:58 pm »
That's what I needed. Thank you all. Now, wish me luck in the junk yard!
