Author Topic: 6-port fuel tank selector valve  (Read 17000 times)
Offline launchpad
« on: April 03, 2014, 02:08:31 pm »
Does anyone know or have a drawing of where what lines go where?    My truck was originally a two tank truck but someone had removed everything.   I'm installing the second take and putting in a new selector valve but I have no idea what lines go where????   On one side i have a small and large inlet/outlet and on the other side I have two small and two large inlets/outlets???
Re: 6-port fuel tank selector valve
« Reply #1 on: April 03, 2014, 04:12:58 pm »
These route to the front of the truck - the 3/8" is fuel supply to the pump and the 1/4" is fuel return to the tank.  Both lines connect to the engine mounted fuel pump if carbureted - or route to the throttle body if TBI.
...and on the other side I have two small and two large inlets/outlets???
The right pair routes to the right tank, the left pair to the left tank.
Offline launchpad
« Reply #2 on: April 04, 2014, 12:53:01 am »
shouldn't matter but it's the 6.2 diesel....   thanks for the info!!
« Reply #3 on: April 04, 2014, 11:02:13 am »
Well, this and similar questions come up so often I was focused on gas rigs... but you're correct.  It doesn't matter.
