Author Topic: Looking for V Belt set up  (Read 4388 times)
Offline 86gmc23
« on: April 03, 2014, 08:48:43 pm »
Just bought a GM Goodwrench Crate motor. I'd like to put the old V Belt setup on it but only kits I found are around a grand. I don't care for the Chrome stuff, anyone have any ideas where to find cheaper kit. I need crank, water pump, alt, a/c, and power steering.
Re: Looking for V Belt set up
« Reply #1 on: April 03, 2014, 08:56:11 pm »
Offline 86gmc23
« Reply #2 on: April 03, 2014, 10:32:01 pm »
No but thanks for the great site. They got all the pulleys needed, think I'm going to water jet my own brackets.
Offline hondaman
« Reply #3 on: April 04, 2014, 04:38:38 pm »
I just did a GM goodwrench motor in my 1981 c10 truck.  I used this pic as a reference.
Offline 86gmc23
« Reply #4 on: April 04, 2014, 08:16:01 pm »
Thanks for pic that's a great ref. You know where I can get a set of brackets like those?
Offline hondaman
« Reply #5 on: April 04, 2014, 09:50:35 pm »
Those are all factory brackets.  I think there are 6 total.  2 for the alternator, 2 for the power steering, and 2 for the A/C
Offline 75gmck25
« Reply #6 on: April 05, 2014, 07:44:15 pm »
Did you have an engine before you bought the crate motor?   I just moved all my stock brackets over to the new crate motor.
My '75 350 had brackets like the picture in an earlier post, except I have an A6 compressor and I think the one in the picture is a R4 compressor.    My original compressor and brackets were missing, so I found another set of brackets in the junkyard.  GM used the same bracket and belts setup in cars, so there were a lot of vehicles to pick from.
You also need to make sure you get everything with the right number of grooves in the pulleys.  I think the crankshaft pulley has three grooves (alternator belt, PS pump belt and AC belt, the water pump has two grooves (alternator belt and PS pump belt, and the compressor has one groove.
With AC you should use a longer PS belt that also goes around the water pump, but without AC the PS belt only goes around the crankshaft.  This means that when you have AC the water pump is being driven with two belts, which keeps the cooling system working if either the PS belt or alternator belt breaks.
Bruce
