Author Topic: Tranny change  (Read 3306 times)
Offline duramaxman06
Tranny change
« on: April 07, 2014, 03:31:54 pm »
My truck came out with overdrive transmission now has turbo 350 what will I run into if I put overdrive back in
Using Tapatalk
Re: Tranny change
« Reply #1 on: April 07, 2014, 04:08:05 pm »
More info on what you have for gear ratio, tire size and type of engine/ stock...  It all makes a difference as well as how you use it...
Re: Tranny change
« Reply #2 on: April 09, 2014, 09:36:26 pm »
Are you wanting to know what needs to be changed to do the swap?
move the crossmember mount, potentially a new drive shaft, trans and converter... short answer.
Re: Tranny change
« Reply #3 on: April 16, 2014, 12:03:54 am »
IF your th350 has the 9" tail shaft you can just put a 700r4 in its place with no new drive shaft. if its the 6 or 12 you can do the math you will be plus of minus 3" and you will need a new shaft. but both trans use 27 spline output shafts so you can reuse the old yoke
