Author Topic: Steering Issue  (Read 3036 times)
Offline Silverado1979
Steering Issue
« on: April 07, 2014, 04:13:06 pm »
My steering wheel will roll to the right if i let go of it. The truck drives perfectly srtaight if the wheel is held. Is this a wheel allignment issue or a steering box tuning issue? This happened because i was driving with a slowly leaking tire on my front passenger wheel.
Re: Steering Issue
« Reply #1 on: April 07, 2014, 07:11:44 pm »
     If your front passenger tire is not flat now, you need to check the steering components to make sure everything is lined up.  I would not guess your steering box is out of adjustment or alignment because you drove around with a tire that was low.
     Did it steer straight before the tire issue ?
Re: Steering Issue
« Reply #2 on: April 16, 2014, 12:08:35 am »
if you wore the tire down odd it will pull to that side even air up.
