Author Topic: Half ton van front suspension - the same as half ton truck?  (Read 8341 times)
Offline mechanic58
« on: April 08, 2014, 06:53:48 pm »
I have a '92 half ton chevy van that has some damaged control arms on the passenger side. They look identical to the '73-'87 half ton chevy truck front suspension to me - can anyone confirm this? It would make my junkyard crawl a whole lot easier.
I like junk
Re: Half ton van front suspension - the same as half ton truck?
« Reply #1 on: April 08, 2014, 09:52:09 pm »
     I don not know for sure, but I just did a search on 2 different auto parts sites for suspension parts and the G10 did not match any of the C10's parts.  So I am going to say no, but I could be wrong.  You could go into your local part store and give them the years for both and see if they pull up the same part number.
Offline mechanic58
« Reply #2 on: April 09, 2014, 05:23:14 pm »
Thanks for the reply, I did the same thing as well today and I did confirm that they are all the same. There is a different upper control arm and knuckle for the half ton trucks (and vans) with a heavy duty brake, but that's the only variable. Upper and lower control arms are the same between the G10 and C10.
I like junk
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
« Reply #3 on: April 10, 2014, 12:00:19 am »
Numbers sometimes lie. A hood for a 1956 chevy with the V8 emblem will have a different part number then the same hood with a straight 6 emblem. If one of the parts you're looking at had a simple hole for a wire clip the numbers could be different.I've found a few parts guys who know this and are willing to pull parts for me so I can do a visual comparison.
Offline mechanic58
« Reply #4 on: April 10, 2014, 07:20:40 am »
If you go on rockauto.com and check the part number for an uppper control arm for a half ton chevrolet pickup ('73-'87) you'll find out it's the same part number for a half ton van from '73 all the way until they changed the bodystyle in the mid-90s. The lower is also the same. The difference between the vans and the pickups is the track width (different k member) and the tie rod assembly.
I like junk
