Author Topic: Cruise control wiring.  (Read 15314 times)
Offline chase.grantham.7
« on: April 09, 2014, 10:39:34 pm »
I have an 82 silverado, it has a blinker/cruise control stalk without wiper function. I swapped a 6.0 in and I'm wanting to hook up cruise control, it needs a momentary for accel/decel and on/off switch, I wanted to use the stock stalk/switch but I don't think it will work. Every picture of the stock wiring I can find shows a wire with a flat blade that appears to have 2 maybe four terminals on it. Does anyone have the schematics for the stalk I have, it doesn't "plug" in it has a screw that holds it on. I have ordered switches I can mount in the dash but I really want to use the stock parts. Are the "set" and "coast" buttons momentary? How many poles does each switch really have?
Re: Cruise control wiring.
« Reply #2 on: April 10, 2014, 04:44:22 pm »
Yes I did now, thanks for the info it's exactly what I needed.  I think I have a way to make it work, let me know what you think. I can connect 12v to the center pin and pin 3 will be energized when I switch the cruise on, pin 1 will be energized when I hit the set button and I can connect 1 and 3 to a relay for the resume button, is there anything wrong with this? I am attaching the stock schematics and the directions for cruise for drive by wire.
« Reply #3 on: April 15, 2014, 08:35:04 pm »
Should work.  Let me know what you find.  I have a cruise setup for mine that I haven't tackled yet.
« Reply #4 on: April 25, 2014, 12:25:51 am »
Finally started to try to tackle this on my truck today.  Everything seemed to check out using an ohm meter, but I think after hitting the switch a few times something inside broke. Where there once was a perceivable click from off to on there is now no resistance on the slider until I slide it to resume, and now the leads don't ohm out.  I want to get another turn/cruise stalk, but it seems I have an odd year or something; the stalks I find are either turn signal only or are turn/cruise and wiper, my truck's wiper controls are in dash.  I've looked on every parts site I can think of rockauto, ,oreileys,autozone,napa, even ebay and can't even find a picture of this stalk. Does anyone have an idea of where to go to find this? I'm attaching a pic of my steering wheel and stalk.
Offline hatzie
« Reply #5 on: April 25, 2014, 06:00:39 am »
Try Dakota Digital HND3...
From orbit on my Android.
« Reply #6 on: May 05, 2014, 07:22:33 pm »
If you are interested, I sell all of Dakota's stuff...
Offline marcoman
« Reply #7 on: February 24, 2020, 04:13:54 pm »
Hey,
I know this is an old thread but I was wondered if you ever solved your cruiser control issue? I'm looking to do an LS swap (n the future) and trying to figure on dealing with this. I hope you can share some kind of update? Thanks.
