Author Topic: door fit  (Read 3048 times)
Offline zach.davis.712
door fit
« on: April 11, 2014, 02:29:23 am »
will doors off a 1980 gmc cab fit an 87 chevy cab i ask due to the change of front end not quite sure if that would cause door fit issues
Re: door fit
« Reply #1 on: April 11, 2014, 07:10:03 am »
     Read through this thread, will answer your question.
Offline BADAZ chevy guy
  • Chevy! My drug of choice!
Re: door fit
« Reply #2 on: April 11, 2014, 12:24:32 pm »
Are you looking to just swap doors or do you want to upgrade to electric windows and locks. If the latter, I did this to my 73. I used 85 burb doors and they fit perfectly. Also, I found a wire loom (Just the part for the door lock/windows) from a 82 or 83 PU and worked it up under the dash. Once I figured I needed to ground it, it worked great.
