Author Topic: 75 k 20  (Read 10975 times)
Offline Dan75k20
75 k 20
« on: April 15, 2014, 09:29:51 am »
Basket case
Sent from my SM-T217S using Tapatalk
Offline Dan75k20
Re: 75 k 20
« Reply #1 on: April 15, 2014, 09:34:02 am »
Offline Dan75k20
Re: 75 k 20
« Reply #2 on: April 15, 2014, 09:34:55 am »
The first pic is from the day I bought the truck
Offline Dan75k20
Re: 75 k 20
« Reply #3 on: April 15, 2014, 09:38:01 am »
Then I replaced the leaf springs with one ton springs minus the top helpers I also added 2 leafs I cut the total cost to do this was about  200.00
« Last Edit: April 15, 2014, 12:50:13 pm by Dan75k20 »
Offline Dan75k20
Re: 75 k 20
« Reply #4 on: April 15, 2014, 09:49:01 am »
Offline Dan75k20
Re: 75 k 20
« Reply #5 on: April 15, 2014, 09:49:47 am »
What the engine looked like when I bought the truck
Offline Dan75k20
Re: 75 k 20
« Reply #6 on: April 15, 2014, 09:50:56 am »
Offline Dan75k20
Re: 75 k 20
« Reply #7 on: April 15, 2014, 09:52:28 am »
Now not much different 600 1405 edelbrock and different valve covers
Offline Dan75k20
Re: 75 k 20
« Reply #8 on: April 15, 2014, 09:55:42 am »
So after I fixed the leaf springs the trans broke behind the governor
Offline Dan75k20
Re: 75 k 20
« Reply #9 on: April 15, 2014, 09:57:30 am »
So I ordered this the monster th350 heavy-duty trans 1014 bucks with a 1650 stall converter
Offline Dan75k20
Re: 75 k 20
« Reply #10 on: April 15, 2014, 10:04:17 am »
Other things I had to do, install new e brake cables all brakes and hardware were new when I bought the truck also has to replace brake lines and the master middlemof the truck rearward tires were almost new 33 12.50 16.5 also had to buy a battery it has 3 inch duals with flowmaster 40 series imalso had to replace the cam lifters timing chain
Offline Dan75k20
Re: 75 k 20
« Reply #11 on: April 15, 2014, 10:06:00 am »
Offline Dan75k20
Re: 75 k 20
« Reply #12 on: April 15, 2014, 10:06:59 am »
That was 2 weeks ago
Offline Dan75k20
Re: 75 k 20
« Reply #13 on: April 15, 2014, 10:09:23 am »
Offline Dan75k20
Re: 75 k 20
« Reply #14 on: April 15, 2014, 10:19:14 am »
i also swapped the transfer case from a 203 to a 205 its still ugly needs a bed I found a solid bed  I am going to pick up in a week or 2 a couple doors and a newer style front clip Ihere are some of my small modifications under hood light jeep speaker bar jeep ribicon seats not installed yet
