Author Topic: My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration  (Read 581710 times)
That is a diaphraghm clutch.  That is what I used.  Mine was a Zoom though.
Offline FearNoMan78k10
  • A project turned into a complete rebuild
So is this a good one to use?
Sent using Tapatalk
78 k10 4x4
you should be fine with it.
Okay good Capt I'm hoping so.... Hey tell me if you see ANYTHING out of the ordinary here.....
Sent using Tapatalk
78 k10 4x4
What do you guys think?!?!
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Tell me what you think chevy brothers!?
Sent using Tapatalk
78 k10 4x4
Offline Engineer
What is the casting number on the heads?
And what are the brand/part number of your pistons?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Engineer they are 781 heads... Not sure the part numbers on the pistons.... I'll have to get that soon for you...
Sent using Tapatalk
78 k10 4x4
Offline Engineer
Those heads are a newer model year version of my 049s. Awesome heads. I put 2.19/1.88 valves in mine with bowl porting. I also polished the combustion chambers. Cleaned up the intake ports to match the gasket where it meets the intake. Amazing power. Amazing torque.
I guess it is too late to change your pistons. I am running SpeedPro H426P pistons with my 049s. They have a .100" dome on them. With the 110cc chamber that the 049/781 head has I am at about 9.6:1 compression. It is what I used as my sled puller for years and now it is going into my monster truck. When I wasn't sled pulling that engine pulled gooseneck trailers, and worked on the farm. I never had an issue with overheating or spark knock.
Your compression is going to be in the low 8s with those pistons. At your high altitude in Colorado especially, you could easily get away with the higher compression. A lot more power potential for no penalty by bumping up the compression into the 9s.
Also, if you are dropping a 454 into a truck that previously had a small block here is what you need to do..... When I did mine I used the rubber engine mounts that came with my truck. Eventually bought new ones, but the old ones worked.
HERE IS WHAT HAS TO BE CHANGED TO MAKE THE SWAP WORK CORRECTLY:
The steel, or engine side, "clam shells" must be changed to avoid your headers from hitting the frame, and to keep the fan from rubbing the bottom of the fan shroud.
Small block mounts will work but the engine sets too low in the frame in order for it to work properly. BEEN THERE DONE THAT.
Search around the internet and swap meets for GM part number 14067103. This is the steel mount used on the 454 engine from 1973 all the way up until the 2000 model year when GM quit building the GMT-400 series trucks. It is a discontinued part number but NOS parts are out there. Buy two of these. One for each side of your engine.
Thanks for all the great advice Engineer I appreciate it..... Here are the pistons with the numbers.... I have heard they have a forged number but have casting marks....??? Something isn't right..... Help me out here..... From what the shop said.... It is going to be 10:1 compression... They said I will have to run premium gas  and nothing less to have it run and work right.... I can tell you what they did to the heads if you'd like.... And motor too.... As far as exact specs .... I don't have that data....from the shop... And kinda disappointed I don't... Hey Engineer... And anyone else.... Could you help me find the parts I need online to get this motor in?  GM part number 14067103... Help me... Please.... It's at a stand still at this point until I'm able to find those correct mounts.... I need the chevy community's help and yours too Engineer....
Sent using Tapatalk
78 k10 4x4
