Author Topic: My 78 k10 4x4 build thread -454 install / build -1 ton axles- frame restoration  (Read 581733 times)
Offline FearNoMan78k10
  • A project turned into a complete rebuild
I finally have some pictures to share with you guys! The big block is installed! Headers on! Accessories on! Bolted up to trans! Engine secured with new brackets and motor mounts! Finally! Just need the power steering pump pulley and waterpump pulley! The ones I have don't fit..... So trying to find some pulleys that will actually work and fit properly. Exhaust still needs hooked up to headers and welded and driveshafts need rebuilt for the Dana axles.... I'm stoked! It's pretty much near ready to test fire and break in the engine! Then drain the oil and put fresh oil in it and finally drive it!  I'm pumped to hear it run! I'll post a video up the day we crank her up!
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
Sent using Tapatalk
78 k10 4x4
