73-87 Chevy & GMC Trucks
A/C comp with headers?
Topic: A/C comp with headers? (Read 3968 times)
BADAZ chevy guy
Chevy! My drug of choice!
April 21, 2014, 07:03:55 pm »
1977 Chevy C10 350ci motor.
I want to keep the A/C, but I also want to go with headers. Are there after market brackets for either the OEM compressor, or a later model compressor?
CAUTION! Do NOT open vent wing if speed is above 130 MPH!
My build threads:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28250.msg235337#msg235337
http://67-72chevytrucks.com/vboard/showthread.php?t=624182
bake74
Re: A/C comp with headers?
April 21, 2014, 07:42:11 pm »
Why wont the brackets you have work ? I know there has to be headers out there that will fit without changing the brackets. Or do you have a set you want to use and know they wont fit ?
74 k10, 77k10 Tom
BADAZ chevy guy
April 21, 2014, 11:20:04 pm »
The stock brackets mount over the exhaust manifold. About 2" from the heads. Headers are only about 1/4" thick at the flange.
My build threads:
dvdswan
April 22, 2014, 08:17:29 pm »
can you use a steel tube cut to the correct length to make up the difference of the header and exh. manifold. kind of like how some alternators have.
Dave
78 K10 Stepside
http://s36.photobucket.com/user/dvdswan/story/10553#
April 22, 2014, 08:20:45 pm »
Did you search the site, is yours like this:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11882.0
BADAZ chevy guy
April 22, 2014, 08:31:43 pm »
I didn't think about using a tube, but I think that may just be the answer. I'd like to see how the later model compressors mount.
My build threads:
